Went to shift into a lower gear at the start of my ride yesterday and the lower lever suddenly swung back with no resistance on it. Trigger still works to go into a harder gear and no way to shift back to an easier gear. So it seems the cable is still in ok but something has gone awry inside.
On a quick Google I got some hits referring to this failure being common ish in XT 12 speed shifters but hadn’t read this before.
Has anyone had this and found a way to fix it? I’m assuming it’s terminal but have a very cheap slx replacement on order from Merlin (so it won’t have the double shift up of the xt but is apparently a lighter shift as a result) so happy to dismantle it and have a play around to see if it’s fixable.
