If, looking at your roof from the inside and see slates, resting on battens (inch square maybe) which run horizontal, which in turn sit on rafters (four by two inch maybe) running from the head of the wall to the ridge board at the apex, then you’ve got a typical pre war roof. Felt or hessian sarking material as an additional layer is sometimes there, sometimes not. If you’ve got something like rockwool, you need a really big depth (200mm+) to get up to spec. To fit this you’ll have to add a big structure to the existing rafters so you can get that depth without compressing it. With most of this stuff you have to leave the last 50mm below the slates and battens clear to allow for airflow otherwise any moisture rising through the insulation or finding its way from above will not be able to get away.
So if you’re going for rockwool style stuff you ave to build out a frame to tuck it into which is rigid enough to plasterboard to.
Next option is if you’ve got high density rockwool slabs, easier this time as they’re only two inches thick. you could whack these straight in between your rafters if the rafters are bigger than 4" so they sit flush and still leave an airspace behind(you may need to add wire or netting to keep it from shifting). They don’t usually quite get you up to building regs part P, but if this a DIY renovation who’s to know when it was done, before or after PartP? To boost their u value thjough you could easily add rigid board such as Kingspan below before plasterboarding, or quicker still use plasterboard with insulation pre-bonded.
A rigid board such as Kingspan could be put between rafters (same as before you won’t get full depth reqd by regs just between rafters), but it’s less hassle to run it(70mm+) under rafters and attach plasterboard below. Because of the hassle of fixing plasterboard with huge screws it’s as easy to fix a run of battens in 2×1 or so underneath it to fix plasterboard to.
Easiest of all is Triso 10 which is a big roll of multilayer foil, just 30mm thick. Roll it out along the rafters, stapling as you go, overlapping and foil taping the edges. Add a layer of battens to make an airgap to the plasterboard and nail them up. You need noggins at the PB edges but that’s it. Oh I appear to have gone on a bit.
