Home Forums Chat Forum Using a woodburning stove as an outside heater …… no door…..
Viewing 7 posts - 1 through 7 (of 7 total)
  • Using a woodburning stove as an outside heater …… no door…..
  • sharkbait
    [history]I have a smallish Jotul stove outside in the barn that was given to me but I haven’t got round to refurbing it yet, so it’s a bit mucky, slightly rusty and has no glass in the door.
    [/history]
    Got a few friends popping round for a little BBQ [gas so no extra heat] and a few drinks later today – would it be daft to put the stove outside by the table.
    Is it going to work without the glass in the door/a door?
    (I was going to put a 4′ piece of single wall flue on top to keep the smoke away from us)
    Nobeerinthefridge
    It’ll be no worse than a chiminea.
    Junkyard
    it will work but it will also go through wood quickly and not get as warm as intended
    You can use them with the door open if you like but you then have, mor eor less, an open fire
    Fine for what you want
    sharkbait
    Partially blocking the door isn’t going to make any difference really is it.
    But the entire stove will still heat up and emit heat so better than an open firepit in that respect.
    * makes note to order new stove glass. I’ve only had it 3 years 😳
    sharkbait
    Nearly ready to go – just need to chuck it on a couple of bricks. Can’t be bothered fitting the legs as it makes it more difficult to move.
    Got some coal somewhere, may use a bit of that.
    Junkyard
    DONT USE COAL
    not all coal [ or burners] are approved foruse and it may burn too fast and warp/crack your stove
    Best avoided IMHO.
    sharkbait
    Well it was excellent – even MrsSB approved (doesn’t like fire pits because of the smoke smell).
    I’ll put the legs back on it tomorrow and order some glass and seals 🙂
    No coal used either.
The topic ‘Using a woodburning stove as an outside heater …… no door…..’ is closed to new replies.
