Home Forums Bike Forum Tesco torch makes
Viewing 7 posts - 1 through 7 (of 7 total)
  • Tesco torch makes
  • trout
    A great host for a quad MR11 kit. or even a MCE using the stock optic
    Mce in tecso C cell torch using tesco lens :mrgreen:
    this has a good beam for a helmet light to go with your P7 floody bar light
    Innes
    What driver and battery are you using for the MC-E?
    They look good.
    Nice brackets as well, where are they from?
    Innes
    mboy
    Trout, what’s your email address? Got a few questions for ya.
    trout
    Innes
    the driver is a 700 buckpuck I had lying around
    battery 14.8 v lithium ion
    bracket is a lumicycle one
    MBOY-troutie-at-blueyonder-dot-co-dot-uk
    This is such a simple build
    parts needed are
    tesco C cell torch £10 / £12 seems they have been cheaper in some tescos
    series wired mce on a 20 mm star
    700 ma buckpuck driver or driver of choice.
    a small slug of aluminium for the heatsink
    trout
    Vortexracing
    Will a cutter lens fit it?
    it looks like it does, just checking.
    and
    I assume you drill and tap the housing for the lumi clamp?
    BTW very neat and cheap.
    looks spot on.
    well done.
    trout
    Hi Vortex
    the cutter lens is a perfect fit will need a bit of silicon for waterproofing
    drill and glue in a captive nut for the mount as there is not enough meat to take a tap unless you put a larger slug in and tap that.
    which is what I have done for the quad cutter one.
    :wink:not really my own idea Smudge did a cutter one before xmas
The topic ‘Tesco torch makes’ is closed to new replies.
