Home Forums Chat Forum Tell me about catapults
Viewing 40 posts - 1 through 40 (of 69 total)
  • Tell me about catapults
  • mastiles_fanylion
    Want to rid the garden of pests (tree rats, pigeons etc). Don’t want to kill or maim anything though, just do enough to startle them.
    I was thinking about a black widow for accuracy but is it likely to seriously hurt anything?
    duntstick
    Only if you use 3/4″ ball bearings………..apparently 8)
    coffeeking
    You stand in the tree, I’ll practice against you – lets find out.
    valleydaddy
    yes depending on what you use as ammunition.
    BadlyWiredDog
    No, if course not, how would projecting a solid pellet at very high speeds into a living creature possibly harm it? How about something noisier, like a shotgun? Or maybe some sort of tactical nuclear weapon?
    CaptainFlashheart
    Yes.
    Either embrace teh fluffeh or embrace your inner Nuge and kill it and grill it!
    (Squirrel and pigeon are both mighty tasty)
    Elfinsafety
    Have you, even for one split second in your selfish and homicidal drive to want to kill things, considered the implications of a stray BB or stone flying off beyond the boundaries of your garden by accident?
    This is a child’s face:
    Do I need to spell it out to you? Do I? Hmm??
    mastiles_fanylion
    @valleydaddy – so is there a specific ammo I can use? Something like rubber bullets for catapults?
    Rubber_Buccaneer
    You will kill things with a catapult in the unlikely event you actually hit anything. Have you considered a water pistol?
    mastiles_fanylion
    Elfin – if it went past the tree they all live in, it would end up in a private field full of sheep.
    donsimon
    I’d suggest getting a guard fox, but according to most people they only come out at night.
    carlos
    A decent Super Soaker/BFO Water pistol/Gun thing will do the job nicely and won’t put any windows through or P off the neighbours if it goes a bit stray.
    duntstick
    A spring lamb recklessly shot by a catapult, just imagine…………
    BadlyWiredDog
    Ace, because rubber bullets never hurt anyone, right. Apart from the odd blinding incident. Go and google images for ‘rubber bullets’.
    CaptainFlashheart
    duntstick, I can work with that;
    CountZero
    Blowpipe with rubber tipped darts?
    donsimon
    I’m imagining.
    EDIT: Must Google faster, even if mine does look tastier. 😉
    valleydaddy
    leos dried peas are the best 😀
    molgrips
    Cat?
    Elfinsafety
    And what if there are children in the field, petting the lambs? Hmm? Have you considered that?
    No you haven’t, because you’re too intent on killing things to satisfy some sort of primal lust, than to consider the danger to children’s faces. So selfish. 🙁
    If you must, then get a pigeon and rip it’s head off with yer teeth then hold the body aloft and let the blood drip over your naked body.
    Might be an idea not to let yer neighbours see you doing this. Can be awkward later down the local Gestapo office…
    CaptainFlashheart
    even if mine does look tastier poncier and comes with a “jus”
    FTFY
    RichPenny
    How COULD you 🙄
    Nick
    Not sure what you think you’ll achieve by startling them anyway, they’ll come back if there’s food to be had.
    Get an air rifle and do the job properly, and eat the proceeds. Better than going to a supermarket for some cling film wrapped protein.
    mastiles_fanylion
    Badlywired you seem intent on assuming I want to hurt things but I don’t ( see the op). And there would be zero chance of blinding anyone but myself given the garden backs on to a private field.
    A water pistol MAY work but the pigeons especially sit high in the tree and I an not sure it would have the range.
    CaptainFlashheart
    That’s a fluff overload right there, RichPenny!
    RichPenny
    Aye, could stick in throat 😉
    donsimon
    I wouldn’t know about poncey, Captain. 😉
    sweepy
    pea shooter and dried peas, brilliant fun
    mastiles_fanylion
    Look – field! Sheep! No children!
    BadlyWiredDog
    No, I’m just a little incredulous that you have to ask on a forum whether something designed as a hunting weapon is likely to hurt anything… what were you thinking?
    And then you come up with rubber bullets as an example of harmless ammunition…
    I’m surprised that you haven’t asked whether using a high-powered water pistol is likely to make anything wet… 😉 Mind you, you’d probably opt for a water cannon instead…
    Flame thrower? Is it likely to damage foliage?
    molgrips
    Fire some lit bangers into the tree?
    paulosoxo
    Burn the **** tree down
    mastiles_fanylion
    What was I thinking? See the original post and work it out FFS! If there is no option available to use a catapult without hurting them then I won’t get one. Which was, err, the point of the question in the original post I made. Originally.
    duntstick
    Vegetables as projectiles, less harmful to the environment
    BadlyWiredDog
    Marshmallows. If you heat them first, they’re like Napalm, but non-fatal. Clogs up their fur and means other animals will lick them compulsively, but will wash out with heavy rain or if you put the animal in a washing machine. Harmless to lambs and small children as well.
    CaptainFlashheart
    Are you suggesting that putting small children in a washing machine is safe?
    1freezingpenguin
    Only if its set to delicate’s.
    CaptainFlashheart
    Delicate’s what?
    mastiles_fanylion
    Delicate’s delicates?
    Kuco
    Pigeons and squirrels are vermin, get a proper gun and shot them if its safe to do so.
The topic ‘Tell me about catapults’ is closed to new replies.
