Home Forums Bike Forum Stuck seatpost Tweed Run bike
Viewing 27 posts - 1 through 27 (of 27 total)
  • Stuck seatpost Tweed Run bike
  • rocky-mountain
    I have a great 1980’s Dawes mountain bike I am using for the Tweed Run.
    My problem is that the seatost is stuck and I need just to raise it a little.
    Any thoughts on a quick fix to unseize it, its steel and a alu post. Heating will be fine as its painted in a rather fetching Hammerite finish.
    rickon
    Unlikely anything will work that will save the post. Google caustic soda seat post.
    doubledunter
    You could try Plusgas but tbh it never worked for me though ,seatpost was stuck in a One one 456ss frame, ended up throwing the lot in the skip, but I do know it has worked on occasions for folks, worth a try 🙂
    simondbarnes
    Home
    rocky-mountain
    hi
    not worried about the seatpost, I can hopefully get another…
    rocky-mountain
    or do i just grin and bear it, its not a huge amount i need to raise it by
    Wookster
    Second the seat post man, he saved my bacon in the same situation.
    superstu
    Vice and use the frame as leverage. Penetrating oil helps.
    Or
    Caustic soda. Just do it outdoors and wear gloves. Foul stuff but effective.
    Freester
    Freester
    coomber
    Throwing out a frame because of a stuck seatpost. ouch. Caustic soda works I’ve don’t that and even the hacksaw way does. Would never skip a decent frame for that reason.
    Sheldon Brown has lots of ways.
    Also, try plumbers freeze spray. That can work.
    tedspecial
    Worth a shot:
    Mix up some olive oil and some ladies nail polish remover (acetone). Give it a good dousing and leave for a while.
    Can’t remember where I first heard of it, but I use it all the time on seized bolts on the car. Works much better than WD40/Plusgas etc.
    beeds
    Yo if your near a decent Bike shop they should be able to do it
    My local Edinburgh one http://www.harts-cyclery.co.uk/
    cheers
    mick_r
    Caustic might also trash the paint…..
    I’ve had one VERY stuck (no amount of vice etc would shift it).
    I cut it off flush and reamed it out with expanding hand reamers. It worked perfectly without harming the frame, but took hours and produced buckets of sweat. Next time will be the seatpost man…..
    superstu
    Don’t bother with WD40, waste of time.
    Vice is easiest solution. Caustic soda can damage paint but is a good choice, never heard of it not working.
    Penetrating oil, messing with temperatures or cutting and ‘crushing’ can all work
    rocky-mountain
    back ground is; the bike was chained up for a year or so in my village. some nice bits on it; campag chain set, suntour thumbie. had a word with the local pc, who said lets unclip it and i gave a donation to a local charity.
    so its been outside for a long time; i cannot shift the bottom bracket, so the method of attack is from above.
    coomber
    If it hammerite painted then blow torch the bottom bracket shell. That’ll get it out. I had a 25 year saracen like that and it worked brilliantly
    tedspecial
    What happens when the owner comes back from traveling to find his bike’s been nicked by a local scrote with assistance from the police?
    silverneedle
    You can drill a hole or pair of holes all the way through the post and slot a steel bar or pair of bars through it it will give lots of leverage but ruin the post. hammering the bars first might jar it loose, get it to move even just a little and work some oil in to it.
    spooky_b329
    I spent a few days removing an oversized post from an old bike. Regular soakings in plusgas but what sorted it in the end was removing the saddle and smacking the post with the biggest hammer I could find. Once I’d bashed it down a half inch I refitted the post and found I could twist it out (still took two evenings I seem to remember!)
    paule
    How much do you need to raise the saddle? If it’s less than an inch, you may be able to sort it with a taller saddle…
    rocky-mountain
    tedspecial; it will be legal and you would have done it too…
    rocky-mountain
    I think I iwll try the saddle and slimmer pedals, got some bear traps on at the moment. Also some penetrating oil and or plus gas; i dont want to wreck the frame, with just a few weeks to go.
    JohnClimber
    Don’t risk it.
    Use the seatpostman
    10/10 plus he saved my seatpost as well
    chiefgrooveguru
    I freed a stuck Gravity Dropper main tube with boiling water on the frame, freeze spray down the post and a big hammer to break the bond. Then used two G-clamps to grip and twist it out.
    MadBillMcMad
    & I’ll third – the seatpostman.
    rocky-mountain
    well… it happened!
    screwfix no nonsense penetrating oil, sprayed it on, brushed the area first with a small wire brush and hey presto… this was on 30 year old frame left outside.
    all replies appreciated, but do go easy first.
    anyhow, rode the bike with the right height saddle on my test trail and crikey a 30 year old bike rides really good and I mean good!
The topic ‘Stuck seatpost Tweed Run bike’ is closed to new replies.
