As above, wd 40 works when mine sticks
Also as above when mine sticks is usually one of the cylinders (not sure if that’s the right terminology is stuck out of line with the rest (key won’t go all the way in) so after WD40, a thin jewelers /electricians screw driver (or similar thin thing) can be inserted into the barrel to tease the offending cylinder into line with the rest,, which allows the key to go all the way in again.
Normaly happens on the bottom one on mine so the key looks like it’s all the way in as a casual glance but it’s not quite..a torch and a look down the key hole might help see what’s going on
Also on mine if you if you put the key in upside down it will turn a bit then jam so make sure you try the key both ways.
