A quick one for a Friday morning, I’ve fitted a new set of forks to my bike after I buggered up the stanchions on the other ones by getting a lump of rick stuck between the arch and the stanchion at a particularly muddy race.
It’s been years since I last fitted a star nut into a steerer and it didn’t go that well – slightly wonky – as I don’t have the correct fitting tool thing.
I do however have a load of the compression type bungs, given that all the assembly does – be it star nut or bung – is allow you to pre-load the headset bearings and then clamp in place with the stem, does it matter what method you use? The bearings loaded up nicely and there’s no front end wobble.
