Has anyone put Hope Ebike cranks on a 2018 levo? Just wondering what q factor is best to go with.
Being as the cranks came out a lot later than the 2018 levo I want to check if the old levo's still have the same q factor as the new ones.
Hope make 3 ebike cranks. Normal, narrow and specialized.
Thanks
I have the Specialized fit Hope Cranks on my 2019 Levo, easy to fit and no issues since, I didn't even consider the other sizes as I assumed they were for other brands. They feel much stiffer than the stock Praxxis ones.
Thanks Paceman. The otger two q factor options say for Bosh motors and the other one says for Brose motors so you can see why it's a bit confusing.
The specialized q factor ones have q smaller q factor than the others which I presume means the specilaized brose setup is a wider axle than other brand motors.
