Flat mount caliper ...
[Closed] Flat mount caliper bolts??
[#12316552]
Hi folks. Im building a bike up and need the above. instead or purchasing the specific shimano bolts at around £3 a bolt can i use m5 hex head bolts the same length?
Posted : 05/04/2022 12:56 pm
Yep! Though from experience... Get stainless ones. 😅
The official ones have that little pin thing on the top to allow you to put a circlip through, but just use some blue threadlock.
Posted : 05/04/2022 1:24 pm
Ahh, i was wondering what that pin thing was for. Its on a road bike, but i imagine that doesn't make much difference?
Posted : 05/04/2022 1:27 pm
The pin's there to stop the bolt unscrewing completely if it comes loose. A bit belt & braces really, but you can make your own mind up as to whether you need it.
Posted : 05/04/2022 5:35 pm
My Diverge came without any clips on the bolts and I've changed the rear calliper twice since. Bolts holding fine still.
Posted : 05/04/2022 5:52 pm
DIN912 in A4 stainless.
Job done.
Posted : 06/04/2022 12:31 am
As others have said - regular Stainless cap screws will be fine.
Should be able to buy a bag of 50 from Toolstation/Screwfix.
Posted : 06/04/2022 10:37 am
