@fathomer thanks but it’s ok, I checked with Alan at Pipedream! 552mm is a 140mm 29” Lyrik static, 160mm is 572mm A2C, with 25% sag it’s 532mm (not sure why the site says something different). I also spent a while comparing the side-on photos from that recent bikeradar review of the Moxie, BFeMAX and Forge, and they confirm what I’d worked out.
Apparently the newest Moxie (Mx3) has the top tube off the Full Moxie so it’s stronger and ok with a 170mm 29” fork.
If you run it at 140mm once it’s sagged it will be a fair bit longer, lower and steeper than the geo chart.
The only thing I’m not sure about is whether I’ll have enough spacers below the steerer to fit a MacRide for my toddler without my 40mm rise bars putting my hands too high for when there isn’t a baby on board – but I guess I can get some lower bars…
A Sirius would probably be more sensible but I like how I can charge into things on my Levo with a big fork and big wheel up front so I’m hoping to replicate that on a hardtail – the current one has a 150mm Pike, a 27.5” wheel and is almost as slack, even lower and fairly long so it’s not a massive leap to the Moxie, just a logical progression to an even more illogical bike! 😉
(I’m also liking that my two bikes will have pretty much the same build in case something breaks and I can’t get a part replacement/repair in short order).
