Home Forums Bike Forum SLX 12sp slipping
Viewing 9 posts - 1 through 9 (of 9 total)
  • SLX 12sp slipping
  • I have 12sp mostly SLX on my ebike. Recently replaced cassette and chain, aligned hanger, was working fine.
    Had been using a KMC chain, which was a bit noisy, but seemed to work fine. Started slipping in the highest gear (10t) under load.
    Assuming the KMC chain might be causing excessive wear, have swapped to a new SLX chain and new 10t cog – still slips under load.
    Lockring is cranked up as tight as I’d like to go, I’m assuming the hanger alignment is still ok, as all the other gears perform fine – they are temperamental when it’s not aligned.
    Any ideas?
    TIA
    frogstomp
    Any ideas?
    Worn chainring – check to see if it is ‘grabbing’ the chain at the 8 o’clock position as you turn the cranks.
    intheborders
    Chainring worn?
    FWIW I always replace the chainring when the cassette is replaced.
    Also, why is there “load” in the 10t cog…
    thepurist
    Worth checking the B tension to make sure you’re getting as much engagement with the 10t as poss while still shifting OK at the other end of the cassette.
    When I say load – pushing hard on the cranks even on the flat
    I did set it up with the mark on the cage to align with the largest cog, but will check again.
    Chainring doesn’t look bad, but will consider it as a possible cause
    thepurist
    Actually rather than just the B screw check the whole mech setup – if the limit screw is off that could cause issues too. And how old are the inner & outer cable?
    Around a year for the inner, but the outer is old
    reeksy
    Had lots of trouble with this mech too on my son’s bike.
    Somewhere I read to not set it up to the cage line and you might get better shifting. I think the recommendation was to have a bigger gap.
    coconut
    Check the alignment of the 10T cog, it’s quite easy to tighten a 12speed SLX up with all the cogs aligned whilst having the 10T misaligned slightly. If the 10speed is not bang on flush it will make a clicking noise and start slipping.
