Home Forums Bike Forum Short reach drop bars
Viewing 13 posts - 1 through 13 (of 13 total)
  • Short reach drop bars
  • MadBillMcMad
    Specialized do a 65mm but struggling to see any others in stock.
    Any suggestions and experience please.
    It is for a gravel bike and I’d like it flared. Current bars are 440 wide, and current reach of 80mm
    swdan
    These are 70mm reach and flared.
    https://www.sigmasports.com/item/Zipp/Service-Course-70-XPLR-Handlebar/SRIO
    Did you want alloy or carbon?
    swdan
    These are what I run on my gravel bike
    https://www.sigmasports.com/item/PRO/Discover-Gravel-12-Degree-Sweep-Handlebar/L0DL
    Or these specialized are flared
    https://www.sigmasports.com/item/Specialized/Hover-Alloy-15mm-Rise-Plus-Flare-Handlebar/GMX2
    Seems there are quite a few out there in the 65-75mm range
    survivor
    I’ve got these… 55mm reach and flared
    https://dedaelementi.com/gera-alloy-handlebar
    luv2ride
    Ritchey Beacons, 65mm reach.  Nice flare, wing top with slight back sweep.  Love ’em
    benos
    Good topic. I put a 60mm Cinelli Ant stem on my gravel bike if that’s useful info.
    frogstomp
    Salsa Woodchipper has a 56mm reach.
    rOcKeTdOg
    Ritchey Corralitos 67.5mm drop, 52mm reach
    PXL_20241021_132252166
    MadBillMcMad
    Cheers all, a few there to look over.
    Probably alloy for budgetry reasons.
    jameso
    Pro Discover are a good shape with flare options between 12 and 25 deg. I’ve got the 25 deg version, I like them. 65mm reach.
    fatface1
    Another vote for the Corralitos.
    intheborders
    +1
    Got 46cm ones on my gravel bike, getting a 52cm pair for my Cotic Cascade when it comes in.
    retrorick
    I bought bars 44cm wide with a flare on the drops which is 54cm wide. I needed the 44cm over the 42cm bars that they replaced but the extra flared drop width becomes a problem fitting through tapered bike gates on cycle routes.
    I reduced the reach on the same bike by buying a shorter stem. The shorter stem helped shift my position and weight over the rear wheel on descents.
