Home Forums Bike Forum Rotor Q Ring Orientation … Google Fu Fail
Viewing 9 posts - 1 through 9 (of 9 total)
  • Rotor Q Ring Orientation … Google Fu Fail
  • letmetalktomark
    I’m full of cold and it’s destroying my ability to complete simple tasks … send help!
    I have had this chainring (and it’s pair) for ages and cannot find the sleeve they came in.
    IMG_2484
    1) How do you set the orientation – which section goes behind the crank arm – I’m guessing the bit free of laser etching?
    2) What do the three available positions equate to?  Presumably this is the affect on the “dead” part of the pedal stroke? Is there a good one to start with?
    If it makes any difference it will be going on the Solaris behind in a 1x set up in the outer position.
    The last oval ring I used didn’t play nicely with one knee so I don’t expect this to be a long lasting experiment.
    (I did like Biopace though)
    jameso
    Max radius should be vertical when the fwd crank arm is around 4pm position which is the max power phase.
    1
    letmetalktomark
    @jameso – Thank you – That reads like a line from an astrological horoscope 🙂
    jameso
    Ha..
    I just checked my own oval ring on passing and it’s probably closer to 4.30pm position, but that’s a SS where I climb stood up. For seated geared riding I think the general advice is to hit max radius a bit sooner.
    3
    thols2
    Yes, so with the cranks horizontal, you need to point those white lines at Uranus.
    jameso
    ^ credit where it’s due, that’s good
    letmetalktomark
    @thols2 … Chapeau 🙂
    Uranus is slightly out of rotation but I think I get the jist
    IMG_2493
    About 1600ish
    IMG_2494
    schmiken
    Position 2 is the “normal”, have a read through the following for adjustments:
    https://rotorbike.com/en-uk/blog/how-to-set-your-optimum-chainring-position-ocp.html
    letmetalktomark
    Thank you @Schmiken – I’d seen the YouTube video but must say it didn’t make a lot of sense!
    The article is helpful.
    I’ll see how I get on in position 2 – in the driveway test it felt okay.
