Now that I have a van that tends to transport the bikes the roof rack is coming off the Volvo. It’s a Thule rack with the metal brackets that sit inside the door frame.
The rack has pretty much lived on the roof for the past 3years and consequently the outer lip of the door seal is deformed to the profile of the metal bracket and has worn through in parts. Now while the rack is in place this isn’t an issue as it seals happily. However I’m concerned that with the deformation and the wearing through it might not be completely water tight…
The outer seal appears to be one piece with the main seal and I suspect being a Volvo they won’t be cheap to to replace!
What’s the chances of them returning to shape maybe be a little persuasion with a little heat from a hair dryer or such (little I suspect as I guess they have been stretched) and what would be best to stick the small tears back together with? I’m guessing it’s not a true rubber but some kind of rubberised foam so vulcanising glue you would normally use on rubber seals and o rings is out?
Ta.
