Aeffect doesn’t have axle spacers
Erm it does, at least now. Maybe there were older models that didn’t? It comes in 5 spindle lengths so spacers make sense to allow adjustment of chainlines.
https://www.raceface.com/media/Crank_Q-factors_and_chainlines.pdf
The chainline is quoted at 47.5mm. I strongly suspect that will be ok for a setup that needs a 48mm chainline.
The retailer quotes that not Raceface. RF say 51mm in the document in the link ^. But seems that’s a maximum rather than a set value as it also says
The interchangeable BLACK and WHITE 1mm spacers can be moved from one side of the BB to the other to adjust the chainline and crank clearance
For Cinch 24mm cranks, the Red 1mm spacer and 1 Black 1mm spacer must remain on the drive side crank stopper ring at all times
That means I can move 3 x 1mm spacers to the non-drive side and take the chain line from 51mm to 48mm (and hope the cranks still clear!).
