Home Forums Bike Forum Punctured today
Viewing 14 posts - 1 through 14 (of 14 total)
  • Punctured today
  • 8
    tjagain
    While out on my eMTB with tubeless. As ever and as a good boy scout I knew I had all the stuff needed with me.  Turns out the sealant had all dried up and it wouldn’t seal when reinflated 🙁  No problem – whip the tubeless valve out, tyre off, get spare tube out of my bag.  Its an effing 16″ tube for my trailer!  Fortunately a bike shop was only a half mile walk away
    Warra numpty  Be prepared my arse!
    12
    thols2
    Sealant’s ammonia based, right? Surely, if you add some urine to the tyre it’ll melt the dried up sealant and get it working again. If it doesn’t, then take it to a bike shop and ask them to sort out the mess.
    5
    tall_martin
    add some urine
    I can’t tell if that’s absolutely true or the greatest troll I’ve ever read.
    In either case, Bravo!!!!!
    4
    aphex_2k
    …and if you poop in it, helps seal some of the bigger holes. (Works best if you’ve eaten corn the previous day).
    3
    blackhat
    I think thols is taking the p***
    boblo
    Aye, my ‘favourite’ post puncture cock up is right inner tube/wrong valve length. Ie short valve + deep section rims. I’ve learned the error of my ways and it won’t happen again – until next time :-I
    nickc
    I’d manged to either screw the lock nut down ridiculously tightly, or it’d gummed up with sealant, but I’ve been scuppered by not being able to get the valve out, and that was a long walk home…Every now and then I now give them a turn at home to make sure they’re not stupid tight.
    2
    tjagain
    A big shout out to Dales cycles in Glasgow who sold me a tube. Loaned me a track pump so I didn’t have to use my wee tiny pump and let me change the tyre in the entrance to the shop.  friendly, helpful and kind
    onewheelgood
    Oh, thanks for reminding me! I’ve just treated my road bike to 50mm rims, but I’m still sticking the same short valve tube in my pocket when I go out. Would be completely useless. Numpty.
    cvilla
    Re deep rims, I think you can get valve extenders, possibly worth putting in repair kit…some older spare tubes are very short, must get some myself!
    ampthill
    Other great moments include
    Getting everything sorted, then unscrewing the pump connector, which neatly removes the  valve core with it.
    I’ve not had this yet but one day I’ll need a tube and have to have to deal with the sharks mouth off thorns sticking through the tyre and previously sealed
    goslow
    “I’ve just treated my road bike to 50mm rims”
    My first thought was “how wide?” 🙂
    andy4d
    My last cock up was realising I had a shrader tube in my backpack but the rim was presta. No way was that valve going to go through the rim hole.
    boblo
    You can and I had some on that fateful day. I’ve never been able to get them to work properly. Probly User error of some sort…
    …go through the rim hole
    The 14 year old boy that I (still) am couldn’t stifle a titter at this… 🙂
