Home Forums Bike Forum PSA – Ragley frames for £170
Viewing 40 posts - 161 through 200 (of 612 total)
  • PSA – Ragley frames for £170
  • rwoofer
    Mine is Brand X and always had a bit of side to side play. Thought that was normal.
    Will see when I install my Fox dropper which is more than double the price at RRP.
    kevin1911
    Can anyone comment on whether the 29er frames are likely to have clearance for a 650b plus wheel/tyre combo – a WTB 2.8″-er to be specific?
    1
    iffoverload
    Marley 275, 150m fork @ 30%and a bit sag, very nice  🙂 thanks OP!
    https://postimg.cc/K4c55CNJ
    If anyone is looking for a Blue Pig in Medium I have one thats one short ride old, its too “progressive” for my winter locals. Its mint and comes with headset and RF Ride 170 cranks, maybe a SLX mech/shifter and Deore MS cassette too, just too nice for a winter beater, probably going to chuck a wide range 10 speed on from the old bike.
    Kramer
    @stcolin – yes it is.
    Kramer
    @kevin1911 – the gap between the chain stays on my Marley 290 is 3”1/4 just at the point that they curve in, seat stays are similar if that helps?
    nickjb
    Pretty sure it will. The stays curve in but they actually run pretty much parallel where the tyre sits before flaring out and there is plenty of clearance on my 2.4
    ajantom
    The 27.5 frames will easily fit a 2.8 tyre, so I imagine the 29ers will be fine.
    davosaurusrex
    I cracked last night and ordered a Marley 1.0 for the boy (using a CC, obvs). How are frame and bike deliveries at the mo?
    @dc1988
    – did yours turn up yet?
    nickfrog
    I am fitting a 2.6 (63mm in the real world) on a Big Al if that helps. Plenty of clearance.
    nickfrog
    Hopefully the pics above are working.
    Ragley BIG AL in size L
    RS Revelation 150mm 42mm o/s
    DT Swiss M1900 / 2.6 Schwalbe Wicked Wills
    Trans X 200mm dropper / Shimano MT500 remote / Charge Spoon saddle
    SLX 12 cranks, rear mech and shifter
    SRAM GX chain and NX cassette
    Nukeproof headset and seat collar
    DMR stem and grips
    Hollowgram 35mm 800mm carbon bars
    TRP Slate 4 brakes + centreline 180mm rotors
    12,950g w/o pedals – £1,125 total cost new
    1
    nickfrog
    We need pics.
    *edit, now you’ve added them.
    I like the white now I’ve seen it built – was naturally drawn to the blue, but….
    Got one (blue) in my basket now, maybe I’ll hit buy, maybe I won’t….
    nickfrog
    Yes I considered the blue but I think I would have got bored of it whereas white is a bit more timeless/classic.
    What I have learned from the build:
    – praise the lord for the adjustable travel dropper. It was perfect at 170mm when slammed in the Meta HT and is now perfect when slammed at 200mm in the Big Al, which shows how much lower the new frame is. I would have needed a new dropper without the adjustability as I don’t like unslammed droppers.
    – the frame seems really high quality, perfectly aligned, seemingly good paint, neat welds. The transmission went in and worked perfectly straight away. Chainline bang on 52mm.
    – the external cable routing (unlike the Meta) is very well designed and is quite subtle, particularly as I run my brakes continental.
    – the clearance on 2.6 is excellent, around 10mm each side of the chain stays, 12mm to the seat stays and 20mm to the back of the seat tube, despite the frame being 2.5 max although the Wicked Wills are not very aggressive but still 63mm wide.
    – the forks are a little low rent in action but will be enhanced with the French damper, can’t remember the brand.
    – SLX chainset plays nicely with the GX chain.
    – those cheapo TRP brakes look expensive despite the £70/pair price tag
    nickfrog
    Forks already upgraded to very lightly used 36s Rythm at £200. Total cost down to £1,070 courtesy of the accidental profit on the CRC Revelations.
    suspendedanimation
    Screenshot_20231030_211214_Chrome
    Help an idiot out, why is there a gap on the tube where it doesn’t look like it’s welded through? If you know what I mean.
    White looks amazing by the way. Tidy build
    teenrat
    That to me looks like it’s not been welded properly
    dc1988
    Possibly a manufacturing defect, is that the bottom of the seat tube?
    suspendedanimation
    Its not mine. It looks wrong to me but dont want to say that if there’s a reason im missing
    Loving the build nick
    But that weld does look concerning, hope it’s not as it looks
    superstu
    Build looks great and can’t knock the value of the total bike. However that looks like some poor welding on that photo
    2
    nickfrog
    OMG that weld looks scary. I can’t believe I didn’t spot it, having inspected it thoroughly. In fact it’s the little round black sticker with the frame size seen from the top where the seat tube bends away from the camera. It took me a while to work that out but no bad welds thankfully.
    suspendedanimation
    Ah thank god! Sorry, wasnt trying to rain on your parade at all, just sometimes notice things and wanted to check.
    Now enjoy, looks brilliant!
    Gribs
    That weld looks awful. I’d not be risking riding it. It’s definitely not meant to look like that and thankfully my blue one appears to be welded consistently.
    4
    superstu
    Probably the first time “a sticker” was a good answer on here 😂
    nickfrog
    No, not at all, I am glad you spotted it for my safety and for the best part of a minute I was convinced I had a dodgy frame. I just couldn’t fathom what happened! Cheers.
    In the offending pic it’s also compounded by another weird gap in the weld to the right of the sticker which thankfully doesn’t exist either in the real world, just a trick of the light
    Kramer
    @Gribs
    I also went out and checked my green one after seeing that photo. 🤣
    stevedoc
    As soon as I get home  im checking .. histiera  ensuse
    nickjb
    I think they will all have that sticker.
    Took a punt on a Big Al frame – on CC of course. Let’s see if it turns up
    Does anyone know where to source a spare hanger? My search is fruitless
    cp
    This is it, but everywhere seems to be out of stock
    https://www.chainreactioncycles.com/p/ragley-mtb-derailleur-hanger-2019-current
    Yep
    Meant to order one with the frame, forgot, then went looking. Could be an ‘Oops’ moment when I can no longer get a hanger
    kayak23
    Tommy C on it.
    matt_outandabout
    Tommy C on it.
    But not on cutting gear cables to length. Gnnnnnnnnnnnnnnnn.
    Does it it look like any of these!…
    No mate, but cheers
    Tommy C on it.
    That headset installation brought a tear to my eye.
    And he’s forgot the dropper cable
    1
    stevie750
    Anyone know the max dropper insertion for a large Big Al?
    1
    chakaping
    Same here. Let’s have a whip round and buy him a block of wood?
    And possibly a file so he doesn’t have to de-burr the top of the fork steerer tube by dragging it across his driveway.
    1
    nickfrog
    No but my 170-200mm adjustable travel Trans X fitted just fine slammed which is as well as I needed the full 200mm and I am a compulsive slammer. I am 6ft.
    Unless you’re after more travel I am pretty sure any 200mm will fit as I doubt my cheapo one is optimised.
    In fact if you checked the TransX’s inserted length then that would give you a benchmark.
    On the other hand if you Google “Trans” and “X” you might end up down a somewhat different rabbit hole…
