Presta inflator for...
Presta inflator for compressor…
16 Users
8 Reactions
Anyone care to recommend an inflator with a presta head for use with a compressor? Something like the ParkTool INF-2 but not that because it’s awful.
I have a Draper one but it’s schrader and requires the use of an adapter that is always awkward to get a good seal on so I’m after something with a proper presta head if poss…
Posted : 08/01/2024 6:35 am
Sorry, on the PC now so can post links properly
Yes I saw that but it gets mixed reviews on Amazon...
Prestacycle
There is also the Jaco one which gets better reviews but requires an additional £50 attachment..
Jaco
Just wondered if anyone had experience of any and wanted to recommend..
Posted : 08/01/2024 7:14 am
I have a cheapo inflator, probably similar to your draper, but have cut the schrader fitting off and put on a track pump fitting. You can buy them as a spare part
Posted : 08/01/2024 7:22 am
I use a fabric pressure guage on mine. I've 3 for sale in the classifieds
Posted : 08/01/2024 7:28 am
20240105_132612
Posted : 08/01/2024 7:33 am
I’ve been using a cheapo blue trigger one with a Joe Blow hose grafted on. It works, but it leaks and I’ve had to replace the hose several times now. I decided I was going to treat myself to a ‘proper’ one so watching this thread with interest.
I once bought a Prestaflator and was underwhelmed with how it felt so sent it back. Didn’t actually use it though.
@bikerevivesheffield can you post a link? Can’t work out what you mean. Edit: oh I see what you mean. Not what I need unfortunately.
Posted : 08/01/2024 7:36 am
I’m tempted to try attaching a track pump head but I CBA with leaks and I don’t want one that’s a two/three handed operation to attach. Largely because the hose on the end of the (heavy) inflator is short so always ends up clanking the wheel. <br /><br />How does yours work @bikerevivesheffield ?
Posted : 08/01/2024 7:44 am
This. I got a cheap one from Screwfix, cut the original head off and attached an SKS head.
Plug and play, as they say.
shopping
Posted : 08/01/2024 7:48 am
Murray and Murray reacted
@oceanskipper
The compressor head has a Schrader attachment as on @kayak23 picture. This goes onto the black bit next to the dial. The hose is presta or Schrader
Posted : 08/01/2024 7:53 am
I’m using a pump head from Decathlon on mine and no leaks. Just cut the old crappy standard fitting off. <br /><br />
https://www.decathlon.co.uk/p/twin-head-for-floor-pumps/_/R-p-1006?mc=4413670
Posted : 08/01/2024 9:11 am
I have that SKS head and it's crap for seating tyres as when you take the presta value core out it constantly switches to schrader mode.
Posted : 08/01/2024 9:16 am
Marko and Marko reacted
The simple blower head for the compressor is best for seating tyres once you have the valve core out
blower gun
Posted : 08/01/2024 9:40 am
I looked & looked years ago and messed around with various bodges but then bought an Airshot bottle and haven't used the compressor since.
If I was buying again I'd get the all-in-one track pump & air chamber.
Posted : 08/01/2024 9:46 am
Simple and works. Lack of a gauge is slightly annoying but for getting tubeless seated/inflated it just does the job and is a sensible price.
https://www.gonebikingmad.co.uk/collections/inflation-tools/products/prestaflator-mini-bicycle-tire-inflator-presta
Posted : 08/01/2024 10:04 am
Like others I put a standard track pump head on a cheap compressor tyre gun, couldn't work better tbf and cost me peanuts. But you do need to find a combination of parts that'll play ball, unfortunately bike pumps quite often don't use normal air threads or hoses
Posted : 08/01/2024 3:54 pm
fruitbat and fruitbat reacted
So what’s the best head? Ideally a one handed operation or at the very least one that doesn’t snap closed when releasing and bludgeon your fingers every time without fail like my rubbish Beto one!!’ 🙄
Posted : 08/01/2024 4:10 pm
Topeak Chuck Head DX upgrade kit looks reasonable… might try one of those .
Posted : 08/01/2024 4:34 pm
I assume you're only looking for one to facilitate beading a tubeless tire?
If so, like Nick above, a blow gun is the best thing. Remove the valve core and trigger the largely unrestricted air in through the valve.
I use a mega cheap plastic one with the metal end snapped off and it's brilliant. The snapped off metal end is the same diameter as the end of a presta valve stem so fits perfectly.
You don't even loose much pressure in the time it takes to put the core back in if you use your thumb as a temporary plug then go back to the pressure you want with a track pump.
Similar to this
Posted : 08/01/2024 5:02 pm
Trouble is that Reserve Fillmore valves don’t have a removable core..
Posted : 08/01/2024 5:47 pm
Just the rubber hose works great for presta and nothing to constrict the airflow like track pump heads can do.
Posted : 08/01/2024 5:56 pm
I put a track pump head onto a car schraeder inflator by unscrewing the normal hose and screwing in an air gun blower tube. The track pump head slid onto that metal tube and a jubilee clip secures it. Means I get the PSI rating too, although it's not the most reliable
Posted : 08/01/2024 6:02 pm
scruff, that sounds like a genius idea!
I've been using an old track pump head and a cheapo Erbuaer gun but I can't get the damn thing to be leakfree, plus the head needs replacing.
Posted : 08/01/2024 6:04 pm
I’ve always used one of those cheap brass adaptors. Or failing that a little bit of rubber over the valve to make it thicker.
Posted : 08/01/2024 8:40 pm
The stupid schrader clippy thing on the Draper is a PITA to fix on to those brass adapters. That’s where I’m at now.
Posted : 08/01/2024 9:40 pm
