As Mcc says, P5 chipboard will be fine – also a lot less wasteful than sheets of ply which are ok as long as everything is 400 centres, square and parallel. 18mm is minimum for structural but you can go for 22mm if you want something that feels sturdier as you’ll no doubt end up hanging some joints between joists
If you’re having parquet laid on top, for heaven’s sake, make sure your joists are level before chipboarding – will make your parquet guy’s life easier and give you a tidier floor.
If it’s a subbie fitting the chipboard, make sure they screw it in instead of nailing. It’ll squeak like a bugger after a few years if it’s nailed. All screws (min 2.5x thickness of chipboard) should be countersunk just below the surface for parquet. A bead of PU (or a good glob of PVA) will help joints stay solid.
