Home Forums Chat Forum Micro garden office ideas
Viewing 16 posts - 41 through 56 (of 56 total)
  • Micro garden office ideas
  • AlexSimon
    Any advice on a wet New Years Day?
    jamj1974
    Wish I had some ideas to contribute! I would live to see how this progresses though!
    AlexSimon
    Thanks jamj1974
    I’ll post a full thread when work gets underway. Still finishing the shed project at the moment.
    Which reminds me – I need to upload some more recent photos.
    jkomo
    I’ve got three sides of a wooden conservatory including doors.
    Meant to go on eBay, just can’t be arsed, I can email photos if you think it may be suitable.
    righog
    You could go Full eco build
    Simon dale[/url]
    lammas[/url]
    mick_r
    I’ve been toying with the idea of a shed using a turf roof on a tubular supporting structure (stainless or galvanised steel tubes), then add in un-stressed insulated wall panels. I want something that could be easily stripped down if we moved house, and a massive made in-situ wooden structure just seemed the wrong solution.
    http://www.coldsaverpanels.co.uk/index.htm
    Not got as far as finding out costs. Maybe they could be used for the half height / half sunk hobbit idea? I think some of the panels can be made where the structural bits use plastic blocks rather than wooden cores so totally rot proof.
    mogrim
    Will the computer suffer if it’s left for a week in winter (i.e. probably freezing) or is if fine as long as I get it back up to 5 degrees or so before switching on – again is condensation a worry?
    Cold itself shouldn’t make too much difference, apart from the clock battery – that could fail if the machine gets too cold. You shouldn’t need to warm the machine up, either.
    I’d be wary about condensation, though, that could easily cause problems. I’d be particularly careful to resist the temptation to take your freezing cold computer inside to the warmth of your house…
    piedidiformaggio
    I think you’ll need to consider planning permission, or at least check when you know what you want to do.
    I’m putting an order in on one of these tomorrow, with 70mm thick timber
    http://www.logcabins.lv/logcabins/product-range/tf-range/log-cabins-warminster-2-35m-x-2-35m.html
    tymbian
    I’ve just built this for a customer, fully lined & insulated with power. Lights & sockets. The possibilities and build options are endless.. this measures 2.8m x 3.0m approx
    AlexSimon
    mogrim – Member
    Thanks mogrim. Yes, I can see the latter being a problem.
    I’ve been looking at the specs on a few computer bits and it seems they are pretty resistant to temp and humidity, but yes, I need to somehow make sure the computer isn’t the coldest thing in the room. Insulate it from the floor perhaps.
    (it’s a desktop tower because I run dual monitors btw).
    AlexSimon
    jkomo Yes please! – email in profile.
    The build is something I’m looking forward to – I’ve decided that building structures is my new hobby, so I’m not looking for an off-the-shelf solution. But some materials to customize might be interesting.
    AlexSimon
    mick_r – Member
    Yes, this is something I’ve been thinking about too – not necessarily for this build, but I fancy the idea of a steel skeleton for another project.
    This building in particular caught my fancy:
    http://www.finehomebuilding.com/item/6849/the-watershed-a-writing-studio
    AlexSimon
    piedi di formaggio – Member
    I’m not in a conservation area, so as far as I’m aware, as long as I stay beneath 15sqm and 2.4m height, I’m ok.
    AC Power will require Part P notification.
    I haven’t looked into stove chimney regulations yet, because from reading people’s thoughts above, It may be too small for one.
    Trekster
    mick_r – Member
    Scaffolding? 💡
    jkomo
    Pics sent
    AlexSimon
    Thanks jkomo – as mentioned in the email, I couldn’t possibly use all that glass – probably only one window and one door, so it’s probably best going to someone else.
    I hope you can find someone that can use it all!
The topic ‘Micro garden office ideas’ is closed to new replies.
