Hi, son has a small conservatory, 10′ x 6′ attached to his house. It’s 20+ years old. Upvc frame, double glazed but the roof is simple plastic triangular sheets slotted into the frame. It’s a pitched roof.
The conservatory has very slightly shifted over time, so nothing is quite square. When he gets v v heavy rain, he gets water dripping thru the roof. A couple of years back, applied roofing tape over the roof struts where the sheets slotted in, and all good.
But leaks have occasionally reappeared, only when v v heavy rain.
Have had a roofer around, and 2 conservatory firms, but understandably they’re not keen to work on it as it’s fiddly, out of square, and old.
Rebuilding is not a financial option for him.
So pragmatic repair…along the lines of putting an additional roof on top, whether some rigid plastic sheeting, car port style, or felt sheets. Doesn’t matter if it blocks the light (an advantage probably). Not sure how feasible to batton onto upvc?
If it can last 5 years then great.
Daft or sensible and advice welcomed (as obvs I’m not a roofer).
