Home Forums Bike Forum I can't get the key into my bike lock.
Viewing 15 posts - 1 through 15 (of 15 total)
  • I can't get the key into my bike lock.
  • Kunstler
    I should have bought a better lock. Don’t fancy hack sawing through a D lock. Maybe some WD40 into thr tumblers, anything else to try?
    ojom
    Tactical nuke.
    Your dropout hanger is here now btw
    GrahamS
    Probably rusted up.
    Good spray of WD-40 followed by some light oil. Plenty of jiggling.
    If that doesn’t work, angle grinder!
    kcal
    yes, having had this, make sure you’re using the right key 🙂
    failing that, is the key not going in, or not turning?
    if the former, maybe a nail file or craft file to get a better entrance for the key..
    Kunstler
    Cheers tbc. I’ve already reached defcon 4. Mushroom cloud of poor anger management over Leith imminent.
    ojom
    My gramps will know someone well shady who can liberate it no doubt…
    Ask him about ‘Fingers’.
    TuckerUK
    Is this just a euphemism and you’re actually asking for ‘relationship’ advice?
    Is your key too big to fit the ‘lock’? Is the lock brand new and unused? Is your key hard and solid, a soft bendy key won’t work.
    Kunstler
    Lock is one month old and the key only goes in half way. Lesson learnt not to buy cheap.
    Kunstler
    Edit – that’s not replying euphemistically TuckerUK!
    bencooper
    WD40 or GT85 in the lock. Can you borrow a set of lockpicks? Lifting each pin on it’s own can fix it.
    woody2000
    I’ve had this on a chain lock before, the tumblers/pins seem to get out of line somehow. I’ve found that persistence works, as does a gentle tapping and shaking of the lock head whilst trying to get the key in.
    Kunstler
    Sorted. WD40 followed by key in the lock and a few persuasive clouts from the hammer. Phew
    soobalias
    now either throw it away, or drip some real oil in there to stop it happening in another month
    i smeared my key with grease and its been sliding in and out a treat for the last three years
    bencooper
    Graphite powder, not oil – oil will just gum things up…
    stuarty
    Your not ment to fix it that quick.
    And not before some one reminds you it could kill you
The topic ‘I can't get the key into my bike lock.’ is closed to new replies.
