A little update on progress. I nipped past the machine shop today to drop off the correct exhaust valves. The guys were pleased with the sleeved repair on the corroded cyclinder. The sleeve is in place and it and the other three are being bored out to +40. The crank has been polished, but is still standard, it and the big ends will see new bearings. A new oil pump and timing gear should see it almost as new.
I drained the gearbox yesterday and found a couple of bits of what may be a synchro ring or locking tab. I’d hoped the gearbox would be ok, but now I’m sceptical and am thinking of having it stripped and checked. There’s a good Land Rover independent in Walkerburn near Innerleithen who may either be able to rebuild the box, or supply me with another one. We will see what the survey says.
The axles and springs came back from blasting. When pressing in new spring bushes, we spotted a couple of leaf springs had broken. The cracks weren’t visible before the blasting. I opens the door to a parabolic spring upgrade which should improve the ride.
I’ve press fitted the shackle bushes to the chassis. Despite making a special tool to press the old ones out, I had to resort to hacksawing and chiselling them out. I’d left them in during the galvanising process for fear the coating would reduce the bore size making refitting the bushes without a reamer, impossible
Hopefully the engine rebuild will go ok, I’ll need to give it a thorough clean internally and I’ll paint the outside too. It would be a shame not to. I’ve got everything to rebuild the axles, which should be straightforward. Once those bits are in place it’ll start to look like rolling chassis again. I like to feel as though things are moving, however glacially, in the right direction. Rainy weekends are the only free time I can muster at the moment
Pics on Instagram
