Home Forums Bike Forum Hope hub problems!
Viewing 13 posts - 1 through 13 (of 13 total)
  • Hope hub problems!
  • Turnerfan1
    Just stripped a Hope Pro 2 rear hub.
    Done it countless times but now I stumped!
    Put New bearings in and xd body.
    Freewheels fine out of bike but when In bike tight,freewheels forward and locks out backward?
    What have I done wrong?
    Small 3 mm washer behind freehub body as well!
    Max
    wwaswas
    you’ve put it in the drop outs upside down.
    MadPierre
    pawls and springs in the wrong way round
    Turnerfan1
    Yeah,
    Checked pawls were round right way and they were same way as old freehub!
    Thought Hope was playing some cruel joke!
    Turnerfan1
    Ahh,
    Cassette is locked in frame,not moving.
    Max
    wwaswas
    I’d go with spacers then.
    Turnerfan1
    There is only one.
    Just the 2mm one behind body.
    Haven’t touched the body as brand new.
    Any others I mite have missed?
    Onzadog
    Pro 2 or pro 2 evo?
    Rorschach
    I had exactly the same thing.It’s the end cap fouling the cassette.Even though hope only .list one 142 end cap I’ve got 2 slightly different ones (older pro2 evo)
    A wee bit of dremel work and it works ok now.Had me stumped for a bit though.
    senorj
    I had an end cap catching on the bearing when quick release was tightened.
    Looked like the end cap had worn down a bit,washer behind end cap sorted.
    I keep forgetting to get new end caps!
    Turnerfan1
    Mine is a Pro 2 straight pull which I think is the same as the Evo.
    I am running the old q/r end cap.
    I know they provide a spare cap for 142 but this bike is q/r.
    Which part of the cap do I need to dremel?
    Thanks for the advice guys.
    Max
    dirtydog
    Put New bearings in
    I would double check they’re fully seated before letting loose with the dremmel.
    Maybe double check with Hope, don’t think xd drivers work with non Evo Pro 2
    Turnerfan1
    Ended up buying new end cap from Hope.
    Problem sorted!
    My old one was breaking up and o ring kept falling out.
    New one is slightly different but seems to have done the trick!
    Thanks guys for advice.
    Max
The topic ‘Hope hub problems!’ is closed to new replies.
