I recently noticed that the lower bearing in the bottom cup of my integrated headset sits a bit loose, i.e. it does not fit snugly, but there is a little bit of play between the bearing and the frame.
After greasing the cup and correctly torquing the top cap and stem, the headset begins to creak after riding just a few rough sections of trail, or slamming on the front brake hard.
The frame is a 2015 Cube Stereo 140 Super HPC TM 27.5 (carbon frame) and the headset is from Hope.
Possible solutions that I can think of are:
a) Making a shim out of a Coke can – could this damage the frame?
b) Trying to find a bearing that is slightly larger in diameter, though this would probably require a lot of trial and error.
What do you think?
