Home Forums Chat Forum Fix my tap please
Viewing 9 posts - 1 through 9 (of 9 total)
  • Fix my tap please
  • zippykona
    It leaks from the area marked. TIMG_20240413_204416_250~2he tap doesn’t drip from the spout.
    I know how to get to the leak and I’m assuming there is a washer in there.
    Are the washers all the same size?
    andy4d
    The last couple of taps I fixed used a valve/cartridge thingy. I just replaced the whole valve as it was only a few pounds from somewhere like screw fix. The whole unit just screwed in and out. One was a balls to unscrew as the limescale buildup had practically welded it in place. Unscrew the cover circled and see if it’s a valve or not. IANAP.
    1
    fossy
    Youll need to isolate it, remove handle, then get into the gubbins and take that to a plumbers merchant or B&Q. Not all tap parts are the same and there are loads of variation in threaded lengths etc. Last two sets of ceramic cartridge replacements have been bodging parts from the new one and chucking alot of the new cartridge away.
    1
    johnners
    In the old days leaking from the spindle just meant repacking the gland with PTFE tape or similar, no isolation necessary for that job. It’s probably an o ring on a modern tap, but as suggested above safest to isolate, strip then take any bits you’re unsure about to a DIY shop.
    thelawman
    IANAP either, but I’ve dismantled one or two taps because we have a bit of trouble here with limescale. That doesn’t look like the sort that takes a £5 ceramic cartridge – as you suspect, it’ll be washers or whatever around a spindle. Washers are as cheap as chips, but gotta be the right size.
    matt_outandabout
    I also find that cartridge size is an issue – you need to whip it out and measure things like diameter, length of cartridge and length of spindle.
    FWIW, I bought a new tap last time as it was getting on a bit. It was easier than to replace the cartridge as I had the time before.
    Bear
    I would try to identify it and replace the cartridge if it is a ceramic disc tap.
    Tom83
    If it’s a branded tap, you might have joy getting a new cartridge. If it’s a cheapy from abroad, just scrap it and replace the tap.
    trail_rat
    Look in the Tap magician site if you know what tap it is.
