Home Forums Bike Forum di2 junction box or bar end?
Viewing 6 posts - 1 through 6 (of 6 total)
  • di2 junction box or bar end?
  • atlaz
    Just speccing out my new build. Is it worth going for the bar-end ports or sticking with the usual 3-port under-stem thing?
    SamB
    I’ve just upgraded from a 3-port to the bar end. It’s a bit of a faff to fit, but it’s SO much neater in use. Definitely worth the change if it isn’t much more expensive.
    atlaz
    I think it’s about 5 euros difference. I need to check with the guys at r2-bike that they have given me all the right cables.
    On the subject, if I want to use the app to change settings do I need that Bluetooth/ant component?
    orangeboy
    Bar end plug is every time.
    for blue tooth you need WU-111 and the newest seat post battery
    battery should be less of an issue on a new build just a problem when upgrading older bikes
    Blazin-saddles
    I wouldn’t change a bike already set up, but if building new I would go for bar end every time.
    atlaz
    Yeah, it’s a completely new setup
The topic ‘di2 junction box or bar end?’ is closed to new replies.
