Home Forums Chat Forum Car woes – new engine?
  • This topic has 171 replies, 60 voices, and was last updated 7 years ago by pauljones1-spam.
Viewing 12 posts - 161 through 172 (of 172 total)
  • Car woes – new engine?
  • codybrennan
    Result! V happy for you.
    windydave13
    Good work fella
    Flaperon
    Also I can’t see how unlocking the doors would command the glow plugs on. Surely you’d just end up with a flat battery especially if you were a seriel door unlocker/locker? I’ve got a common rail VAG product to look at tomorrow so I’ll check your theory/information.
    Unlocking (or opening) a door does loads of stuff on a modern car. Fuel pumps fire up, computers wake up, the sat nav starts acquiring satellites, the headlights run a self test…
    I’d bet that most people who go to a car and unlock it after it’s been sat for a while have some intention of driving it. Because it’s a car. 30 seconds of glow plugs won’t drain the battery.
    You can tell in cold weather because you can hear relays clicking as high power consumers connect to the battery, and partly because if you spend ages fannying around getting stuff out of the car and then go to start it, you have to wait for a glow plug cycle before the computer will turn the engine over.
    mcmoonter
    Feel good factors are seldom as good as when an engine transplant works. Woo hoo!
    Mowgli
    Thanks all. Can confirm it drives. Very similar to how it was before, perhaps slightly less grunt (if possible from a 105hp!) but goes reasonably well. Bit smokey when cold, and the Emission Workshop! warning is still there, but I suspect this needs to be cleared manually even if the fault has gone away. Tried disconnecting the battery for 15 mins but it remains. However it’s the only fault left so I’m not too bothered for now.
    Thanks again everyone.
    Murray
    Well done sir! Respect!
    oldnpastit
    Awesome!
    trail_rat
    Just goes to show that even in these days of computers and shit for cars never forget the basics.
    Fuel air and current (IE check your wiring in a diesels case-fir a petrol it would be spark)
    jambalaya
    This 🙂
    Inbred456
    You have just completed one of the most complex jobs you will probably ever do on a car, you Sir are now in a very exclusive club.
    Well done that man. Go and have that beer.
    oink1
    Regardless of how many engines I’ve done (In dealership with all tools/tech data) you can’t beat that Yessss! feeling when it lives for the first time 😀 Props to ya OP 🙂
    Marko
    Sure does, but on VAG group product it DOES NOT fire up the glow plugs*. KOEO required.
    *Checked on a 05 plate Touran with BKC PD engine and 2013 Caddy with CAYD CR engine.
The topic ‘Car woes – new engine?’ is closed to new replies.
