Anyone about 5’7” and can advise on the sizing of these?
I am 5ft 9 with a 30″ inside leg and I was worried when the medium turned up but after setting up the axle centre to saddle height the same as my other bikes I have just over the minimum seatpost showing for a 125mm drop reverb.
It depends on your upper body though and if you want a dropper. You should get away with a 100mm drop post on a medium assuming a leg height of 29″ and the reach should be fine as it has a set back post and I could do with a bit more length in the TT but wider bars on the stock length stem should help open up the cockpit a bit.
I would be tempted to say air on the side of caution and got for a medium but best thing to do would be measure the dimensions of your current bike, assuming you are happy with the fit, and compare them.
