Home Forums Chat Forum Can flour go stale?
Viewing 12 posts - 1 through 12 (of 12 total)
  • Can flour go stale?
  • gobuchul
    I have a jar full of plain flour,
    Rarely used, it must be a year old.
    Need to make some yorkies tomorrow.
    Should I bin it and just buy some more?
    Don’t like food waste but don’t want crap yorkshires tomorrow.
    1
    nickc
    Does it either; smell bad, or clump together or has it got a yellowish tinge to it?
    Any, all these things, then yes, it’s gone past it’s best, and you should probs buy some new.
    thols2
    Check to see if it’s mouldy, smell it to make sure it doesn’t smell off, then bin it and get some fresh stuff.
    You could just mix it up with some water to make dough and bake it and use it as bird food if you’re bothered about wasting food.
    ElShalimo
    it’s always best to use freshest flour you have. It’s probably okay fro today but older brown flours with seeds should really be used by the BB date – something to do with oils breaking down
    @MrOvershoot
    will be able to explain much better
    hels
    Yes, and it can get weevils which are very obvious,  lots of tiny holes in it, and tiny worms.  I never keep any flour for long.
    andrewh
    If it’s kept dry it lasts for ages, not sure how long but a year should be fine.
    Self-raising does seem to loose it’s raising ability over time though, so add a bit of baking powder after a few months
    andrewh
    IIRC @mrovershoot on here works in a flour mill and should be able to give a definitive answer
    fossy
    Keep ours in air tight containers
    gobuchul
    Well it looks fine, is still white and isn’t lumping together. Kept in an air tight container.
    Regards weevils, we are too far North for them.
    However, when we lived down South, we had a jar of self raising flour that got infested, it must of been unopened in about 3 years, when we opened it, it looked like they had built some kind of alien settlement in the flour!
    I still might buy a new bag just to be on the safe side.
    thecaptain
    Flour keeps pretty much for ever if dry and uncontaminated.
    or if baked into Christmas cake.
    mrchrist
    If it looks and smells ok then sieve it before you use it to make sure there.
    Sounds like it will be rite.
    4
    MrOvershoot
    Some one called @MrOvershoot
    I don’t work in flour milling now!
    I retired after 31 years in it, though it’s not changed in the 2 1/2 years since I finished.
    IMO and with my knowledge based on storage of 1000’s Tonne’s at a time, after 6 months it starts to drop off in baking quality that’s for a strong white bread flour 12.5% protein and above.
    White cake/biscuit flour up to a year but you will have variable results if your product has fruit in i.e. in a cake it will all sink to the bottom.
    Brown & wholemeal flours can go off in 3 months depending on the wheat germ level, wheat germ goes rancid pretty quickly as the natural oils degrade.
    If your plain flour has been in a cool dry dark place & well sealed then it should be OK, obviously if it has a musty smell then it probably has flour beetle in it pretty much all flour has the possibility to have confused flour beetle or flour mite’s in due to their eggs being so small that they are impossible to sift out with even the finest sieve meshes.
    Some cake flour will have been heat treated to kill off a particular enzyme that effects the baking process and by doing so will kill any eggs.
