Home Forums Bike Forum Brake conundrum-tech advice/opinions
Viewing 9 posts - 1 through 9 (of 9 total)
  • Brake conundrum-tech advice/opinions
  • chilled76
    Evening all,
    Just bled my shimano xt (785) rear brake three times. Using various methods.
    1) back bleed using syringe at caliper and funnel at lever.
    2) forward bleed with two syringes
    3) traditional open close bleed port as you press and depress the lever.
    All three times I’ve got a great feel at the lever, no sponge and a full on loud thump as the pads contact the rim. This is telling me I’m pretty sure there is no air in the system
    Yet… there seems to be very little power compared to before changing the hose.
    What the hell is going on? I’ve removed wheel and pads each time so there is definitely no fluid on the pads and rotor.
    chilled76
    Just done another bleed on this. Solid lever feel, full on thump as the pads hit the rotor but no power, really hard to even lock a wheel up.
    Anyone got any idea? Fault in the lever/caliper maybe?
    chiefgrooveguru
    Did you put in fresh pads at the same time?
    garage-dweller
    Not got something oily have you?
    With good feel and initial contact that might be first check.
    Or fluid leaking so as you apply pressure the pads don’t squeeze harder but the fluid is getting out instead.
    sillyoldman
    If it feels solid at the lever, then almost certainly a lack of friction between pads and rotor – most likely oil contamination.
    Take pads out and stick them under the grill/use heat torch on them until smoke stops (all oil burnt out).
    Clean the rotor with isopropyl alcohol and or give very light sanding with wet and dry paper.
    Stick pads back in and bed pads back in again. Should all be good.
    chilled76
    Cheers guys, I’ll try torching the pads and rotor
    andyl
    dont torch the rotor. de-grease the rotor.
    chilled76
    Yeh that’s what I meant. Is isopropyl alcohol just white spirit?
    z1ppy
The topic ‘Brake conundrum-tech advice/opinions’ is closed to new replies.
