- This topic has 67 replies, 35 voices, and was last updated 3 years ago by Speeder.
Bike Check: Dan Milner’s ‘Modern Klunker’ Yeti SB115
continuityFree Member
Firstly, piss off trying to get me to subscribe to read an advertorial.
Secondly, your bike is too heavy. 33lbs for an XC race bike is 10lbs too much.
The only acceptable additions to the “bikes are just heavier now and these additional weights are good” category are: Tyre inserts, wider tyres, wider (to an extent) rims, larger cassettes and dropper posts. To counter this; suspension is lighter, carbon is better, carbon wheels are priced to the masses and machining has improved tenfold.
Ignoring my belief that most people are overbiked and under-skilled (I’m just appropriately biked and under-skilled; and the popularity of electronic motorbikes says people are under-fit as well), XC bikes should be 24lbs or less (and that’s full suspension, hardtails should be under 21lbs). Trail bikes should be 24-28lbs. An enduro bike should be 28-30lbs.
Things that are making your bikes heavy; too much suspension, steel frames because you’re a hipster, steel railed saddles, chunky stems, heavy lock-on grips, cushcore inserts (rimpact are 300g lighter across both wheels, a whole pound), DH casing tyres on xc bikes, cheaply made frame hardware, handled thru axles, lazy thick paintjobs, 14-pot brakes.
You don’t need these things for the nant bield pass (you can ride it on a 21lb xc hardtail), and you really do not need these things for two laps of Barry Knows Best then a cake in the Peaslake cafe.
tomhowardFull Member(rimpact are 300g lighter across both wheels, a whole pound)
Are you sure?
Where is there a 33lb XC race bike?
thegeneralistFree MemberI’m sure continuity is just trolling, but I’m having a slow day….
Apart from his irritating Brexity habit of measuring bike weights in pounds, looking at other specifics;
It didn’t come across like that to me. Don’t be so harsh
It’s not a **** xc race bike. It’s a mtb for doing cross country rides. You could literally call it an XC bike, though most would disagree, but it sure as hell ain’t an xc race bike.
EtctomhowardFull MemberDoes does continuity think that Dan’s bike is 33lbs? Dan’s 13.2kg bike? No wonder it seems too heavy…
danmilnerFull MemberFirstly, piss off trying to get me to subscribe to read an advertorial.
Hi Jospeh, let me help you out here..
The bike here does not weight 32 lbs, but 29.1 Lbs (13.2 Kg). I agree that 33 lbs for an ‘XC race bike’ would be way too silly, but this isn’t an XC race bike. This build sits somewhere between the weights for trail and enduro bikes that you have deemed acceptable to you, which is fortuitous as the bike was intended to span that gap, as I say in the text: to ride long distance multi-day trips but still handle everything in its way (the caveat being that it’s me onboard).
Aside from this weighty point, I’m very glad you agreed with my text in all the other points you raise. And yes I do wish enduro bikes weighed 28-30 lbs (my SB140, with 160 forks, comes in at nearly 32 lbs).
Thanks for reading, and glad you could access this without having to subscribe.SpeederFull Membercouple of quotes from the article:-
one that I could still ride how I wanted to, down any trail my adventures led me without fretting about durability or reliability
but they’re not the kind of kit I’d trust with my survival on remote expeditions
I’m not sure how either of them square up to buying a Yeti. Has something changed? To my mind Yeti means “delicate”, “immature proprietary suspension tech”, “nice colour”, “tribe”. not robust, go anywhere, trustworthy. The “lifetime Warranty” doesn’t help when the chainstays break or the linkage thingy seizes in the middle of nowhere
ayjaydoubleyouFull MemberThings that are making your bikes heavy; too much suspension, steel frames because you’re a hipster, steel railed saddles, chunky stems, heavy lock-on grips, cushcore inserts (rimpact are 300g lighter across both wheels, a whole pound), DH casing tyres on xc bikes, cheaply made frame hardware, handled thru axles, lazy thick paintjobs, 14-pot brakes.
things in bold, I agree with you
I’ve said before that I’m not a huge fan of 4 pot brakes as a concept. However the current offerings from the major manufacturers mean I do have E4 on my big bike. If someone made a comparable 2 pot I’d be all over it. But to internet dweebs more pistons = better and I think that ship has sailed.
I’ve only done nan bield once, and I chickened out an dabbed a foot on one of the top corners. It was a great descent though, and there is no chance it would have been either quicker or more fun on a light weight race hardtail.
Surrey hills I’ve ridden a lot. Trail tyres with no inserts would be my preference, but otherwise I would take the bike you describe as unneccesary. And I’ll wholly enjoy the ride. Not buying food unless its a 4 hour plus ride though.thegeneralistFree MemberThis thread has proven quite enlightening with respect to something I posted a few weeks ago.
That isn’t intended as a dig at you BTW Dan, more am observation on the dynamics. You’ve done that pretty impressive thing of getting deeply involved in the post article discussion and also keeping your cool. 🙂
simonchanFree MemberLove the tongue in cheek Acronym™️. Lovely build and article. Although my local trails are more sedated and my rides shorter, couldn’t agree more with the idea of having a bike to do just enough. Have a pretty similar build with my Ibis Ripley and it’s just fun on almost everything.
continuityFree MemberRides are measured in km, bikes are weighed in pounds. I don’t make the rules; I just guard them.
Got me on the conversion. Someone else earlier in the thread quoted 33lbs so I went with that. However, now you’ve got me on it, you propose that this is the ‘quickest lightest uncompromised’
1. A sb115 is unnecessarily heavy (breaking 2 and 3) – a kilo heavier than an equivalent spark in the same size.
2. Should have been a 34 SC at no loss except weight (2 and 3 broken).
3. 2 pistons with 200mm are lighter and brake better than 4 pistons with little rotors (all 3). Bring back formulas r0!
4. Dissector on the front, dhr on the back!?
5. 2kg for a wheelset…?
6. 213g for a saddle and 110g for grips?
This is just whoever gave you the components. I had access to the article because it’s an advert. Do you think you should have to pay to see adverts?
mboyFree Member@ Dan
Honestly, don’t feel the need to justify your bike to a bunch of strangers on the internet. As another industry professional (and mutual friend of Chipps’), this forum is simultaneously the best and worst of MTBing society. It’s your bike (and a lovely one at that!), enjoy it… If a stranger on the internet doesn’t get why you’ve specced it a certain way, what does it matter?
Was just about to say – its a general do-it-all mountain bike. Why does the bike industry seem so obsessed with giving bikes labels.
Because marketing… 🤷🏻♂️ But then again, that’s testament to the success of the sport/pastime/hobby that the marketing men have got involved. As someone who works in a marketing team for a cycling company, many/most of the terms and acronyms annoy me, and certain brands’ insistence that they need a new marketing buzz word every other year does grate somewhat. But then again, innovation improves the breed, so…
Back to my lust for a RM Element. It ain’t XC, downcuntry or modern clunker, its a mountain bike.
In the classic tradition of recommending what you own, keep on lusting… 👌🏻 I’ve got a 2019 model that I’ve specced up a bit, as an antidote to modern “LLS” yet at the same time still incredibly capable trail bike, it’s right up there. I did look at the SB100/115 instead, and do love the look of them, but the slacker seat angle on the Yeti was noticeable and though the Element has a 1.5deg steeper head angle, it also has a ZS44/56 headset too so it’s easy to rectify this with an angleset.
I’ve picked up loooooads of those Fabric bottles from the side of trails over the years. They seem pretty solid when properly clicked in, but it’s not 100% clear when you post the bottle whether you’ve clicked it in correctly or not.
I’ve seen countless of them dropped off over the years too. Good idea, poor execution sadly!
A press fit bottom bracket – really? I’d be chucking a Wheels or Hope adapter in there ASAP. I don’t think I’ve had a PF BB last more than 1,000km
Nothing wrong with a decent press fit BB, and a lot right with it. I’ll take a decent PF BB with replaceable MR2437 or 6806 bearings over a threaded cartridge unit every day thank you. Less waste, lighter and stiffer interface, cheaper replacements (as you’re only replacing the bearings when they’re worn, not the cups they sit in too).
The biggest issue with PF BB’s is home mechanics insisting they can fix everything without the appropriate tools! 🤭 Which brings me on to this…
It sounds ridiculous. I’m amazed that manufacturers are pumping out kit that make it easy to build a 29lb bike with so little travel for so much money and people accept it. The weights of the bikes in the Pink Bike field test are unacceptable – not one of the trail bikes is under 30lb and they’re all over 5k.
People need to start demanding lighter bikes rather than being sold the lie that bikes are as light as manufacturers can make them for a certain strength. Mountain bikes have been around for fifty years, the technology should exist now to make them lighter as well as stronger but a lack of imagination and innovation on the part of manufacturers is stopping that happen.
There’s many reasons bikes aren’t that light any more (well, some still are). People insisting they can fix their bike at home with a minimum of tools doesn’t help as designers have to design bikes heavier as a result in many cases. But also, there’s the evolution of the trails we’re riding… 20 years ago I was 65kg and rode pretty smooth trails mostly, and any off piste was mostly bridle paths. Riding wasn’t that technical, wheels were 26” and tyres 2.1” wide, and CEN tests didn’t exist. These days I’m 95kg, most trails I ride are pretty technical and off piste, wheels are 29” and tyres are burlier, dropper posts and wide bars are de rigeur even on XC bikes and anything non CEN tested would probably last 5 minutes with my lard arse on top of it… Times change! 🤷🏻♂️
Anyway… Light bikes exist. Nobody is stopping you from buying them. They do cost a lot, and they aren’t suitable for most of what constitutes “Mountain Biking” for the vast majority of riders these days (though they’re equally suitable for the 90’s definition of it, if not more so than a 90’s MTB) as peoples expectations have moved on… I’m just building a lightish XC hardtail as we speak, aiming for sub 11kg with a dropper and pedals included. It will be fun to ride on tamer trails and cover ground quickly I am sure, but won’t be that much more capable off road than a Gravel Bike I suspect…
Aside from Continuity’s obvious troll grumble about weight, his terrible maths and insistence on what he believes people should be riding rather than letting them make that decision themselves… Mountain Biking is supposed to be FUN! Sometimes I think people forget that too readily. Don’t like eMTB’s? Fine… Don’t ride one! But don’t tell the next person on one what they are or aren’t allowed to ride. Same goes for someone on an Enduro bike riding your local woods. From 30 odd years experience riding MTB’s I know all too well that a lighter bike with faster tyres and less suspension travel is usually the most fun, if not the most capable bike to be on for any given circumstance, but we’re all different. Some people enjoy riding uphill ffs! Perverts!!!
SB115 isn’t aimed as an XC race bike, when the Spark is… Similar travel granted, but not designed for the same reason.
34SC is 120mm max travel… The SB115 is designed around a 130mm fork… If it wasn’t apparent already, I’d say facts hold very little substance for you, and you’re one of those people who values the ability to shout the loudest over and above provide a valid and well reasoned response to an argument!
More smaller pistons provide better modulation and feel. As the Pirelli adverts used to say decades ago, “power is nothing without control”. I have yet to find an example yet where an equivalent 2 piston brake can match the modulation or feel of a 4 piston brake, even if it comes close to or matches its power for a given rotor size.
Gotta have confidence in your tyres… Wouldn’t be my choice, but tyres are a hugely personal topic!
Isn’t too bad for a modern 29er trail capable wheelset that doesn’t break the bank. Yes there are lighter, but you’re starting to make compromises on strength or durability as you go lighter obviously.
Is incredibly light for components I’d actually want to use, even on an XC race bike! A saddle is no use if you can’t sit on it for hours on end, and grips no use if you can’t hold onto them likewise.
This is the way much of the media works these days… Don’t like it, then don’t pay for it… Simples! Which shouldn’t be a problem as you’re not by the looks of it anyway!
bentudderFull MemberNothing wrong with a decent press fit BB, and a lot right with it. I’ll take a decent PF BB with replaceable MR2437 or 6806 bearings over a threaded cartridge unit every day thank you. Less waste, lighter and stiffer interface, cheaper replacements (as you’re only replacing the bearings when they’re worn, not the cups they sit in too).
I hear ya. I guess my main argument in favour of a threaded BB instead of PF is that you can generally screw in HTII cups by hand, reducing the need to carry around a threaded bar and adapters. The weight of an HTII is trivial enough that I’d probably throw a spare one in my luggage if I was travelling with my bike these days.
I had a Stache frame with PF and regardless of whether a proper bike mechanic fitted it, or if I did it myself with the correct tools, it ate PFBBs. I’ve had no such problem with a Kona using the Hope adapter, mind, and I’m sure a pair of 6806s could be dug up almost anywhere on the planet, mind so there is that.
qwertyFree MemberThings that are making your bikes heavy; too much suspension, steel frames because you’re a hipster, steel railed saddles, chunky stems, heavy lock-on grips, cushcore inserts (rimpact are 300g lighter across both wheels, a whole pound), DH casing tyres on xc bikes, cheaply made frame hardware, handled thru axles, lazy thick paintjobs, 14-pot brakes.
I’ve just put together an XC trail bike with none of the above. 1900g full suss frame (110/100mm), SID forks, aluminium i28 rims, 2.4″ light tyres = 12.2kg all in including pedals and copious sealant.
Could of saved 200g with an Ultimate Race Day fork, 100g with a Luxe shock, 200g with DT carbon wheelset, more with a spangly top of the range SRAM cassette instead of a SunRace.
It’s as #upcountry as I could make it for my budget.
https://www.instagram.com/p/CXwMpl0MGgA/?utm_medium=copy_link
BadlyWiredDogFull MemberHonestly, don’t feel the need to justify your bike to a bunch of strangers on the internet. As another industry professional (and mutual friend of Chipps’), this forum is simultaneously the best and worst of MTBing society. It’s your bike (and a lovely one at that!), enjoy it…
Erm, I see what you’re saying, but if you write an article saying how brilliant your bike build is, it’s not unreasonable to be justifying – I think ‘explaining’ is a less loaded term fwiw – to posters in the follow-up comments to that article.
But whatever, I think it’s great that Dan’s taken the time to engage with folk on here. It’s a shame that doesn’t happen more consistently.
chrismacFull Member2kg for a wheelset…?
2kg is ridiculous for anything less than full dh duty. This is the problem, media keep peddling the idea that heavy is fine. It’s not
danmilnerFull MemberWell, thanks everyone for chipping in here. I love the debate these kind of features create — especially over bike weights (something that, as an ageing old ex-XC racer turned all mountain enduro upcountry adventure rider and bike-shoulderer, has long been at my heart for years), and I am truly chuffed that my feature has even introduced the concept of ‘interpretive dance’ to the comment forum.
I set out to give an insight into the kind of bike that comes with me to the quite remote, wild or off the beaten track places I go to shoot stories. This bike came with me to Rwanda in October (amazing place: story to come soon) and did exactly what I wanted/needed it to —keep me rolling up and down, and have fun while trying to absorb and photograph an incessant barrage of amazing experiences. Theres enough going on in these places for me to not need to worry about bike reliability or having to handle it like an EWS pro (I leave that to my riders).It does seem from some peoples comments that maybe I didnt explain the component choices well enough perhaps, or maybe some readers own interpretations, or maths, or personal preferences seem to cloud their willingness to just accept this is a bike built by me for the kind of adventures I do: Nothing more than that, albeit with a jangly headline, and you can take my experiential knowledge on what works for me in such places, or leave it. But at the same time I also accept that I have a responsibility to ‘put my money where my mouth is’ if I am going to write/shoot/film this kind of content, and I hope I have helped clarify and answer points in my previous replies. (And no, @thegeneralist, we don’t get anti-prickliness training LOL; it’s just something learnt over years on the job.)
On that note, here are a couple more points (now I worked out how you paste more than one quote in the same reply!)I’m not sure how either of them square up to buying a Yeti. Has something changed?
I know it is currently popular to knock Yetis, and honestly, truly, I cannot find a genuine reason for this. They are not delicate, and they never have been; ever since the first ARCs that were raced, they have been trusted. I have been riding Yeti’s by choice for the last 13 years, through the 575, SB5, SB6, SB140 and SB115. All have been put through the mill in very wild, high, remote places, without letting me down. In all those years and models, I have only had one ‘breakage’ (an early SB6, its ISCG mounts cracked after hitting an outcrop of BB-height bed rock at full, OMG speed —must learn to pull up faster!) but it wasn’t something that stopped play, or the trip, but was only to be sorted afterwards. Yeti have long been associated with backcountry adventures (too much so if you ask some marketing peeps) and their bikes have been trusted by many to explore some of the most challenging places to ride on earth (ask Joey Schusler too). If we adventure dudes didn’t trust them, we wouldn’t take them. Simple. No, OK a lifetime warranty might not help much in the middle of nowhere but it gives you the security of mind that it is very, very unlikely to fail, and frames generally are not the parts to suffer on such trips.
And as for “immature” suspension tech, I’d argue to the contrary. The 575 was as ‘conventional and established’ a design as it gets, and the current Switch Infinity works really well, giving the bike a lot deeper travel feel than it actually has (in a good way), as well as eliminating pedal bob. The ‘fancy link’ (ie Switch Infinity) won’t ‘seize up’ in the middle of nowhere (if you have injected grease a couple of times per year as recommended), and is actually a lot less complex and needs a lot less fuss/maintenance than many other companies’ linkages.
While I am not suggesting that @Speeder, you fit this demographic, it is popular nowadays to choose a scapegoat to demonise in the industry, as part of some kind of personal credibility/power play, and many riders choose Yeti to be it. A while back it was Specialized, who were, quite literally (if you read forums) the spawn of the devil. Today Yeti ticks that box for the opinionated wanting to get noticed amongst their online, anonymous peers, reaching ‘dentist-loathing’ tendrils through the internet like a bike riding QANON. It’s an odd psychological state of play. Perhaps it is because their bikes are expensive, or that they are an independent company, or they liked turquoise before every other company decided they would too… or a mate of a mate of a mate of mine had one and it broke, I think (just like we all have mates of mates who broke a bike by brand X, Y or Z).However, now you’ve got me on it, you propose that this is the ‘quickest lightest uncompromised’
OK, @continuity, as @mboy explains, this isn’t an XC race bike like the Spark fitted with 120mm SIDs, and, again as mboy helpfully points out, most of the other component suggestions you make, while appreciated, are just not valid here for the type of build I have done. If I was building a super light XC rig then maybe. And again aside from the preferred modulation etc, etc, as I explained in the piece, a Shimano XT 2 pot+203mm rotor is heavier than an XT 4 pot+180mm rotor combo. Its just the way they are. I can’t change that. So for the weight saving I would choose better modulation and smaller rotors over less modulation and bigger rotor, and again I have never had fade issues with 180mm ice tech rotors (and I live in the Alps). But hey, thats just me. You can put whatever you want on your adventure bike, I don’t know where you’re headed or how you ride. BTW, as said the Mavic’s came in at 1919g (49g above the factory claimed weight), not 2Kg. It’s hard to really find trustworthily tough adventure wheels with 30+mm rims in a 29′ size for much less weight than 1850g (yes 27.5 would be easier), without going carbon rim or going super exotic — again as I explain, both of which I keep away from for my adventure trips.
continuityFree MemberIf you’ve watched Scotty Laughlan’s series on YouTube (amazing content for free, obviously with elements of advertising benefit for the brands supporting but you don’t mind being advertised to because you’re also being delivered actual content) – the new Spark trail is perfectly capable of ripping down technical mountain descents. Hardly an xc race only bike?
@danmilner As a microcosm of the issue: XT rotors are boat anchors and they deform at high temperatures and so rub. The Formula one pieces are lighter in 203 than the xts in 180. My question still hangs unanswered – can you honestly say you picked these parts off the shelf yourself (even if, say, wiggle gave you a max budget) or were they just what Mavic / Shimano / yeti wanted you/STW to push?I’m (ever so slightly) trolling (well, exaggerating for effect) because I feel trolled by the state of bike journalism (3 page forum thread following a rant in my post history) and this feels like another example of it – featuring the requisite amount of people glibly telling me I should be glad that I got to view the advert without paying (what a freeloading hippy).
continuityFree MemberFYI I’m only human and also lust after a yeti – but think the sb115 is the worst proposition in the range: frame weight about the same as an sb130 but nowhere near the capability.
Similarly, if you want reliable, then why pick a high-maintainance high performance solution (switch infinity link) over a simpler one (something like a spur?). You’d have a better bike with a simpler frame, and could even spec carbon wheels (which don’t magically explode).
danmilnerFull MemberAt risk of this becoming a “you guys should get a room” two or threeway, between us and mboy @continuity I have enjoyed your probing, don’t worry. And I applaud your call out of apparent industry dishonesty. While I am still a little confused by the idea that this is an “advert”, and not “acceptable product placement content” as Scotty’s videos are (would including wild pics of something adventurous helped make it acceptable content? though those are in the video), I accept that I am guilty of conjuring up a clickbait headline that eluded to me building the “quickest, lightest..” and I deserve to be called up on it, as yes I could have built lighter. “Kwicker” on the other hand was always going to be ambiguous claim, as as that depends on my legs, lungs and VO2 max.
So yes, for clarity, I am an ambassador for Yeti and Shimano (as Scotty L is for Scott and Shimano). But they did not instruct me to do this piece, or what to promote or build. They help me with kit each year so I can do what I do. Yes you could argue that by being such an ambassador, then my hands are tied to their products for this build and yes that is right to an extent (although not exclusive, as you see with the saddle, seat post, grips, headset, wheels), but I chose these brands and approached them for sponsorship a while back, rather than the other way around, and that distinction matters. Even handed a golden supermarket sweep ticket around Wiggle, I’d still have spec’d the bike like this, pulling on and trusting my past experiences of components. I have ridden many bike brands (either as my own bikes, or indeed testing many for magazines or at press camps) and I have ridden almost all the drivetrain and suspension option/companies that have come (and gone) over my 35+ years mountain biking. I have never snapped a Shimano crank, but I have other brands. I chose Yeti and Shimano for support as they shone out for how I ride and what I want from my bike: true performance and reliability. It is not a case of “we pay you. so go say this” as you may get with pro racers bike checks etc. If the kit didnt work for me, I’d go elsewhere and build a bike differently.
And yes Scotty Laughland’s stuff is great. He’s a very nice person -we did a big shoot together earlier this year and have joint projects in the pipeline for 22. It will probably also involve products and placements and adverts. But eitherway, as the sort of ex-DH/EWS pro rider that can do anything well on a bike, he could ride a single-pivot Spark, or equally a rusty wheelbarrow, down a clanky hill faster and better than me, so I’ll stick with the Switch-Infinity SB115 and all the help it gives me, thanks.continuityFree MemberFair reply – and I appreciate your honesty.
To answer your question – i think pairing an advert-driven piece with content that explores something else (aka, using the money from the industry to do more than just give a list of parts and some glowing reviews) is a big distinction, and does make all the difference.
In many ways, I also suspect it makes for better advertising for the company – have I not come away with a sense, without him having said a single thing about which wheelset he’s using on the bike, that a Scott Spark could do all of the things I need a bike to do, just because I have watched Scotty do them? Is that not actually incredibly effective?
(Ignoring that I’m nowhere near as skilled a bike rider)
NormalManFull MemberI know a slightly tongue-in-cheek nodded to Dan Milners skill set early on in this thread but I have to say my hat is tipped to him for his follow up comments in here too! (Non sponsored hat I’m tipping just to be clear!)
I’m pleased he addressed the anti Yeti thing too. I am certain, given his talent, if the brand he used constantly let him down he’d be in a decent position to change brands!
I’ve never met Dan, only ever exchanged brief DMs on insta over a podcast he was on (yes, I like Yeti 🤷♂️) but a more genuine great ambassador for the sport I don’t think you could find.
EwanFree MemberAll this time i’ve assumed Dany Milner = Dan Milner of cool mtb adventures! Mind blown.
thegeneralistFree Memberam guilty of conjuring up a clickbait headline that eluded to me building the “quickest, lightest.
< pedant mode>
No, I think you did get the clickbait headline
</pm>Hob-NobFree MemberI know it is currently popular to knock Yetis, and honestly, truly, I cannot find a genuine reason for this. They are not delicate, and they never have been
It’s mostly because of the blind patriotism the fans display. And because they build bikes that fall apart, in the real world.
In the last 7 years, I’ve cracked 4 bikes. 3 of them have been Yeti’s. That doesn’t include the rest of the other warranty issues either (worn SI Links).
I’ll let you work out which of brands was an absolute sh*t show to deal with as part of the warranty process..
IMO they deserve all the sh*t they get.
SpeederFull MemberSorry Dan but whilst I don’t have any direct experience of Yetis and may be somewhat swayed by the general online mistrust of the brand, I do have friends and acquaintances that share similar experiences to HobNob’s.
I wouldn’t touch them, even though they’re obviously pretty cool and look lovely, for me it’s not worth the risk. That’s why I ride a British made steel single pivot. Simple, reliable, repairable.
The topic ‘Bike Check: Dan Milner’s ‘Modern Klunker’ Yeti SB115’ is closed to new replies.
