Home Forums Bike Forum Bearing grease in hand luggage your thoughts
Viewing 11 posts - 1 through 11 (of 11 total)
  • Bearing grease in hand luggage your thoughts
  • hofnar
    So I am flying Spain to Belgium on monday and I need to fix my nieces bike down there.
    Any one flew with bearing grease in hand luggage? Small pot only 100 grams?
    I got a LEGO cristmas tree and raindeer carriage as well but they should be fine.
    1
    Onzadog
    If it’s less than 100ml and presented in a clear ziplock bag along with other toiletries I don’t think anyone will notice, or care
    belugabob
    I’d just buy the grease in Belgium.
    1
    davros
    Smear it through your hair and extract it on arrival.
    Onzadog
    You could decant some. You’ll not need all 100ml
    1
    andrewh
    I had a jar of pesto confiscated as I lost the ‘is it a liquid’ argument.
    How liquid is your grease?
    daviek
    Some may class that as dangerous goods. But as mentioned above get them to buy grease there and use it.
    1
    airvent
    I watched someone get a tub of hummus taken off them at Edinburgh airport two weeks ago, how thick is the grease?
    2
    sockpuppet
    Stick a small amount in a tiny container, put it in your clear toiletries bag.
    2
    timber
    Just tell them it’s lube and give them a wink.
    prettygreenparrot
    It’s probably classed as hazardous. Chain lube is if I remember correctly. Irrespective, a small volume, in an appropriate volume-labelled otherwise non-descript container masquerading as a toiletry product should get by. Do you need to take 100mL? That’s a fair amount of grease.
