I’m making up three small display cabinets – I want to fit an inlaid led light strip into the sides – these are readily available on amazon.
However, ideally want I want is one plug socket / power adaptor and the ability to power several light strips in the three cabinets. So I only need one socket / hide one cable
Not having much luck sourcing, probably not using the right search term…. anyone done this before / recommend a product?
Thanks
edit all the cabinets will be on the small wall but will be set apart from each other by a few inches
edit2 cabinets are different sizes 40×40, 30×30 and 20×20 so strips need to be trimable too or available in those dimensions
