First off yes I have an electrician doing the work, but it’s the weekend so can’t ask him at the moment.
I’m in the process of boarding one of my rooms with 100mm insulated plasterboard. Is it acceptable to drill up from underneath before fitting the board to the wall, into the front of the insulation against the plasterboard?
Effectively I’ll end up with a 400mm channel with 3 sides surrounded by insulation and the 4th side will have the plasterboard infront of it.
The wiring will then be run under the floor and pulled up to each socket.
i know derating is thing but not sure how relevant it is in this situation?
