- This topic has 51 replies, 27 voices, and was last updated 2 years ago by Scienceofficer.
Alternatives to gas boilers
espressoalFree Member
Will it work if the water mains pressure drops to 1.5 bar?
Eventually no, because it will continue to drop, but all you need to do is turn the inlet tap until the dial goes back up, possibly trickier if in the attic.
big_n_daftFree MemberEventually no, because it will continue to drop, but all you need to do is turn the inlet tap until the dial goes back up, possibly trickier if in the attic.
Water companies are trying to operate their network to 1.5 bar in the street. You might be lucky and get more, don’t assume because you get more now you’ll get it tomorrow
squirrelkingFree MemberBit less than lukewarm, has been for years, I turned the dial down one day when it felt a bit hot, I don’t think that is terribly unusual.
You turned the dial down on the tank you don’t actually have? You said:
The tank confuses me, spoke to a fitter and he was trying to convince me it was a miracle solution, storing power being the biggest problem etc etc, it can keep water hot at the same temperature for two weeks apparently, and general dish washing water is luke warm from the warming outer tank, the one I looked at was 3 tanks inside each other, convinced that all works as they said but seemingly if it ever goes cold…you just flip an emersion heater and your free electricity heats it up, sounds too good to be true.
That’s a legionella risk right there. You never tank lukewarm (tepid) water for prolonged periods if at all.
squirrelkingFree MemberWater companies are trying to operate their network to 1.5 bar in the street. You might be lucky and get more, don’t assume because you get more now you’ll get it tomorrow
I find that difficult to believe, how would they service commercial buildings, flats or even houses up hills?
espressoalFree MemberWater companies are trying to operate their network to 1.5 bar in the street. You might be lucky and get more, don’t assume because you get more now you’ll get it tomorrow
It’s a combi boiler? the dial on the front is pressure, regulated by the boiler, there is a natural gradual loss in the pipes so you can manually adjust it with the inlet tap.
espressoalFree MemberYou turned the dial down on the tank you don’t actually have? You said:
I have a combi boiler, gas? it heats my water? I’m considering getting a heat storage tank for solar.
The principle is correct obviously but I don’t think I’m alone in using lukewarm water to rinse a dish, if I am then I’m perhaps immune to legionella because I have done it for years without giving it a thought.
paul0Free Memberdecorative wood burning stove fraternity.
Ha, best line of this thread so far!
Regarding retrofit of an ASHP, I thought this also typically required replacing radiators with larger ones, or switching to underfloor heating, due to the lower supply temp ? So the cost of the ASHP itself is only the start of it.
lovewookieFull MemberThread resurrection.
our combi is perhaps looking to be replaced in the not too distant future, and we are considering (as far as it’s been mentioned) moving away from gas.
However, what if anything?our house is a mid terrace cottage, original build somewhere in the early 1800’s, in the 1970’s a big box dormer was put on it, removing the roof space. Thick sandstone walls, granite chip render on the outside, uPVC windows put in before we moved in.
When we moved in it was a gas boiler for CH and immersion heater tank for hot water. This was changed out when the boiler was condemned, to a combi.
We also have a PIV system to provide fresh air and maintain moisture levels so the house doesn’t go mouldy, and no carpets to help it vent.hearing some getting on OK with ASHP, grants available to make installs similar outlay to new combi, but I have reservations that it’s not going to be a solution for us, in our old cottage.
I think to get it to work, we’d need to insulate under the floors and upgrade the dormer insulation, however I’m concerned that if we did that, the house wouldn’t breathe and things will start to get damp. We’d need to make sure we either re plaster with lime plaster, or gyproc in a way to ensure the walls can remove moisture, even then, i don’t have a lot of faith in uPVC window trickle vents to do a lot of moisture removal, so we’d likely need to install room vents.I think the answer is to change the combi for another combi and hope there’s an alternative to the current alternatives in the years to come, or I get a lot of work done to get the house feeling warm with a ASHP and have a hot water tank again, oh and return to an electric shower too…doesn’t seem worth the hassle unless we have a windfall to completely strip out the lower floor of the cottage!
SuperficialFree MemberRegarding retrofit of an ASHP, I thought this also typically required replacing radiators with larger ones, or switching to underfloor heating, due to the lower supply temp ? So the cost of the ASHP itself is only the start of it.
The issue with GSHP and ASHP is that the temperature differential of the radiators:rooms in that setup is not that great. Instead of piping a small amount of really hot* water around your house, you pump a much greater amount of slightly warm water to achieve the same heating. The trouble is, if your house pipework is made for a recent-ish efficient combi boiler, the pipes are likely to be a small gauge and can’t achieve the flow rate needed to warm the house. So in some circumstances you’d have to replace all the pipework.
I thought this was a problem with newer houses, not old ones. Of course, insulation is another issue.
IANA central heating engineer, I’m just parroting something I heard on Radio 4.
(*piping hot??)
ScienceofficerFree MemberFor you description lovewookie, I expect the energy demand of your house is too much to make an ASHP economically viable.
lovewookieFull MemberSo in some circumstances you’d have to replace all the pipework.
interesting, the grants and associated quotes from local ish folk who’ve had it done includes new radiators, but maybe not new connecting pipework.
I think you’re right.
what other alternatives are there for a flat roof, tiny back garden cottage in a conservation area?
I suspect, not a lot.ScienceofficerFree MemberLots of constraints there by the sound of it. More insulation, draft proofing and MVHR would probably be on my list if possible.
The problem with old houses is that energy flux through the structure was part of the equation for keeping moisture at bay and preventing the materials of the building from breaking down.
This is pretty much at odds with modern energy efficiency thinking.
The topic ‘Alternatives to gas boilers’ is closed to new replies.
