Stupid car design i...
[Closed] Stupid car design ideas of our time
In our MX5 when you change gear into 2nd, 4th or reverse you half open a cup holder.
In the previous Audi A3 when anyone with normal length forearms changes gear into 2nd or 4th your elbow batters off a bizarre arm rest lump thing.
Any Ford where you wash the windscreen, it wipes the wipers, stops then does a last wipe a few seconds later, smearing the windscreen again.
Peugeot vans with the handbrake on the right and where the full beam for the lights is on a separate stalk on the same side as the indicator stalk which you move up or down to go to full beams instead of towards you/away from you. WTF?
Posted : 04/02/2015 11:22 am
Those stupid daytime driving lights on modern cars.
-1
Best thing ever and certainly saves accidents. Don't DRLs switch on the rear lights as well (they do on our cars)?
Posted : 04/02/2015 11:26 am
most of the civic with the pointy bits to stab you, lack of visibility and mismash of spares bin parts to make a dash
Whilst I agree that the rear visibility left a little to be desired, the dash/cockpit was the best in any car I've ever owned.
Posted : 04/02/2015 11:28 am
Mercedes foot hand brakes. I never mastered entering a main road from a side road that was on a slope.
Drls are not automatic lights sharkbait.
Drl are little front lights that cars have on all the time.
I vote any car that has an outward opening door..... You know the type that ding the car next.
After having sliding rear side doors id be quite happy to have sherpa van sliding front doors 🙂
Certainly any family car should have sliding rears to help mum and dad get the kids in as ever time i see a car gettinf "doored" its from a parent strugling with the door and strapping the child in.
Posted : 04/02/2015 11:34 am
I hate the VW multiclick car opening, argghhhh, its stupid.
Audi A3 with only one cup holder in the front, its a £20K+ car and they can't count to two. Plus the ride, if I wanted bone shaking stiffness I'd get horse and cart.
Posted : 04/02/2015 11:36 am
Fair enough.... I'm coming from a the viewpoint of a Volvo owner of about 16 years - they've always called them DRL's but they've just been headlights with the main beam disabled, rear lights were always on.
Posted : 04/02/2015 11:40 am
I find it clears the bits of washer fluid than run back onto the screen. Which is what it's supposed to do.
Posted : 04/02/2015 11:47 am
Also peugeot and citroen cigarette lighter continue to work for 30 minutes after keys out ignition if you put it in eco mode, that is to turn off , remove key and put your radio on then off using the button on the stereo.
Now your 12v outlets will operate for 30 minutes.
Posted : 04/02/2015 11:50 am
dangeourbrain - Member
Not really a safety feature is it...
...to use the power socket with the ignition off.
Unless of course what you use it for is unsafe or accidental, say an actual cigarette lighter which you knocked getting out of the car, a crappy battery/charger which might be prone to catching fire.
Your requirement to have your car broken into because you left your phone on charge leave your phone on charge in a [likely unattended] vehicle because shouldn't trump actual safety concerns
The cigarette lighter can be safely 'knocked'. If you knock it into the 'on' position (which would take a firm button press, rather than a knock, but anyway...) it will just pop up when it reaches temperature as normal. It won't magically pop out of the lighter socket when the ignition is off and set fire to the car. If it is not far enough into the lighter socket for be held in place safely, then it definitely won't be far enough in to actually turn on if 'knocked'.
Crappy battery/charger catching fire - very low risk. Especially if you don't buy cheap crap. I have used 10's (perhaps hundreds) of different chargers over the years for all sorts of purposes both in and out of the car and never had one overheat/explode or catch fire. I'd say the risk is low enough to be negligible.
So, my car might be broken into. Yeah. OK. I can use my judgement about when might be safe to leave a phone in my car unattended.
The one time my car was broken into, I had forgotten to take my phone with me, and get this.......it wasn't even charging!!
When I'm camping, my car is right next to my tent and I want to charge my phone....is it safer to:
a) unlock car, plug phone in to charge and re-lock car, or
b) unlock car, place key in ignition to position II, plug phone in to charge, leave key in ignition, leave car unlocked (with key in ignition).....?
And that's ignoring cars that have a power socket in the boot, in which case you could plug things into them and leave them completely out of view from any would be crims.....
Safety feature - yeah, OK.
Posted : 04/02/2015 12:12 pm
trail_rat - Member
Ooooh, didn't know that. Will have to try it next time I encounter an unresponsive power socket. Cheers, t_r.
Posted : 04/02/2015 12:14 pm
Generation II Smart Fortwo headlight bulb replacement.
It was impossible to do without taking the whole of the front wings, bonnet and ariel off. Even if you trained as a gynocologist you had no chance of reaching the bulbs without doing any of this. Or an hour labour at Mercedes-Benz
Posted : 04/02/2015 12:18 pm
and you still legally need to carry spare bulb kit in several EU countries 😉
Posted : 04/02/2015 12:21 pm
Cup holders in my Clio that you can't actually get a cup/can in/out of without spilling, and if you're in 1st/3rd/5th you just can't get into at all. Then again, the entire interior seems to have just happened by accident
Posted : 04/02/2015 12:29 pm
I get grumpy about my rain sensing wipers and the automatic re-wipe thing on my ford... But it nearly works, and I reckon it's still better than manual. I just wish it had the option to revert to manual, or a little bit more user controllability. Things that nearly work can be more annoying than things that don't work at all!
I never thought I'd trust the automatic headlights but now it seems weird not to have them.
Posted : 04/02/2015 12:30 pm
There's a few that really annoy me, for example the centrally mounted instruments that small car manufacturers seem to love. I don't.
Vauxhall. Now, I've driven a few of them over the years but not one of them has had the steering wheel, seat and pedals properly aligned. All have had varying degrees of offset which have resulted in back/neck pain.
Now, I used to own a Mk 2 Golf, which was designed in the late 1970s. The seat, wheel and pedal position were perfect. All the controls were a finger top away and the stereo was almost at eye level along with the heater. The electric window switches were placed in the centre console, which meant you could raise and lower the passenger window at will. The seats were excellent and supportive and the visibility out of the car was first class.
VW got this right when most manufacturers were still dallying with vinyl seats and bakelite. Thirty five years on there's absolutely no excuse for any manufacturer to make a car that's uncomfortable to sit in and a PITA to adjust the heating.
Posted : 04/02/2015 12:35 pm
 br
[i]This is so trivial but it annoys me... My Mondeo has a 60/40 split rear seat, which is a really good idea. Except the rear bench is a single piece, so you can split the seats if you fold them forward with the base down (which doesn't work very well) but if you want the seats down properly it's all or nothing.[/i]
Funny that the my original Sierra had proper 60/40 folding seats, but the face-lift one had the stupid bench bottom.
Posted : 04/02/2015 12:41 pm
 br
[i] The electric window switches were placed in the centre console,[/i]
PITA having to search to the left when wanting to open the window to my right. Although better than (Alfa) having them in the roof console.
Posted : 04/02/2015 12:43 pm
Everyone complaining about the VAG multi click thing… you realise this can be turned off right?
Just a few clicks with the right stalk in the Maxidot/MFD.
Also Renault Megans, just in general - everything about them is a funking nightmare. Had one as a hire car snowboarding a few years ago, most infuriating heap of turd I've ever had the misfortune to drive.
Posted : 04/02/2015 12:44 pm
Posted : 04/02/2015 12:45 pm
 dday
Car radio (or ICE if you must) in wife's Renault. Get in, start the car, and a few seconds later, blast cheesy pop music (the kids) at full volume. And why cant the radio just turn off when I turn the car off? Why do I have to open the door first?
+ 1 for sat navs that can't search by post code.
Posted : 04/02/2015 12:46 pm
We had one of those! Alfa 164 or 75… can't remember the exact model. It used to look for all the world like you were giving the car behind the finger. Remember baffled by irate drivers until realising what it must have looked like from the car behind!
Hit the (car) power button a second time and it'll switch off. Personally I like this feature - great for when I'm waiting in the car to pick up miss mogrim from gymnastics, stop the motor but not the music.
Minor irritant: the chrome detail on the steering wheel, it catches the sun every now and then with an annoying flash.
Posted : 04/02/2015 12:57 pm
 hora
Headlight main bulb failed on my Subaru Forester and Halfords were doing an offer on pairs so I thought I'd change them both to equal brightness and pop the other in the box as a spare...
One the nearside you have to undo and remove the battery and its sleeve etc to gain access. 😯
So for now, I've left it as it is. I'll change it when it blows not twice 😀
Posted : 04/02/2015 1:01 pm
Vans that you can't get a coffee cup in, but you can get a can of coke in... If you drink half of it and rotate it 45 degrees to get the ****er in!
3 seater vans with 1 cup holder..
The 3rd seat in a Berlingo thing... Even a child would struggle to sit in that half seat!
As a lot have said, ignition turning off after 20-30mins, damn annoying when trying to charge your phone for work.
My car beeps when your turn ignition off and leave key in.. It's more like a flatlining sound, constant, ear piercing and not needed.
Posted : 04/02/2015 1:06 pm
 hora
Key left in ignition is another.
I KNOW - HOW THE HELL WOULD I LOCK YOU WITHOUT THE KEY IN HAND.
Posted : 04/02/2015 1:07 pm
Also, what is it with VAG cars and their insistence that it takes 15 button clicks to open the car?
As has been mentioned, this is a feature which takes 10 seconds to disable if you don't want it. And there is something wrong if you have to press it 15 times. Once for the drivers side. Once more for the passenger side. In fact I think some VAG cars with the higher end Maxidot type displays, you're able to disable this setting without the need to VCDS. You could choose whether to have it or not on my BMW.
A lot of what I've read is just people not knowing how to use their car properly.
Posted : 04/02/2015 1:10 pm
How about the requirement to take the front end apart to change a headlamp or the radiator? I remember, back in the old days, I could take the rad out of my Golf by removing four bolts and a couple of hose clips. These days, it's an hour's labour and the whole front of the car off.
I'm not even going to start on four seater cars that only work for adults if the driver is less than five feet tall.
Posted : 04/02/2015 1:11 pm
My mates Peugeot's has a sat nav that cannot find destinations by post code, you need to know the street name and number.
At first I thought he'd just got the thing set up wrong, but no...it really only wants street names!
I had an Insignia with built in nav that did the same. Used to drive me mental.
On my alfa you can't lift the front windscreen wipers fully off the screen as the bottom of the legs rub against the bonnet.
Posted : 04/02/2015 1:14 pm
am i too late the mention the stupid, hateful, doesn't *ing work when i want it to... auto-dimming rear-view mirror?
what was wrong with the flippy-lever that rear view mirrors used to have?
i'll tell you what was wrong with it, *ing nothing, that's what.
****ing Vauxhall.
Posted : 04/02/2015 1:15 pm
DaveyBoyWonder
Anyway, another gripe - car stereo volume controls that you can catch with your knuckle going round a corner. Instant terrifying volume leap, doesn't help manoeuvrings.
Posted : 04/02/2015 1:16 pm
Passat does that. If you want to lift them you have to flip the windscreen lever down once after you've turned the car off and before you open the door. Flips them vertically. The hiding them presumably improves aerodynamics.
Posted : 04/02/2015 1:18 pm
and while i'm venting,
rain-sensing wind-screen wipers, they can *-off too. i've already got rain-sensors, they're my *ing eyes, i use them for (among other things) sensing rain, mine work better too.
having rain-sensing wind-screen-wipers is like letting a toddler choose when to operate the windscreen wipers, it's more or less random, and extremely annoying.
cars are like bikes, all the problems have been solved, every change from here on will only make things worse.
Posted : 04/02/2015 1:20 pm
willard - Member
There's a blown bulb in my dash. I've not even bothered to look up how to change it, I'm just assuming it'll be a 5 spanner job that starts "dismantle entire car"
Posted : 04/02/2015 1:31 pm
The bolt that holds the boot gas strut onto a Touran.
To access the bolt inside the rear pillar, you need to cut a hole in the bodywork, tighten or replace bolt, weld hole back up and re-spray back end.
I have an email from VW GB admitting it was an issue that they and VW Germany had no solution to, and were very sorry for.
(Or use a Riv-nut and epoxy as we did)
Posted : 04/02/2015 1:51 pm
My Vw Touran has 13 cup holders but only 7 seats!
4 (1 in each door pocket)
2 in the front centre console
2 in the glove box
1 in the rear part of the centre console for the middle passenger
2 in the fold out aircraft style tray things
2 in the boot for the fold up rear seats
But it doesn't have a Curry hook 😥
Maybe Vw where hoping Cup holders would become one of the stats for top trumps.
Posted : 04/02/2015 1:53 pm
automatic headlights, seems to result in people driving around in fog/rain with no lights. Me included when I don't remember. Surely a bad idea?
keyless entry that randomly doesn't work. Automatic locking that works a little too much.
Molgrips - useful windsreen wiper info, this had been bothering me on my Skoda.
New VAG you can change pretty much all the features through the MFD, including how many clicks to open the drivers door.
I think all my car gripes have been covered though. Most annoying is making it hard to change light bulbs, luckily as I have a titchy engine I can now do this easily.
Posted : 04/02/2015 1:54 pm
Ironic you've learnt how to insert gifs into a forum and yet you've not learnt to read an instruction manual. Very odd...
Posted : 04/02/2015 2:00 pm
 hora
[img] ~c200[/img]
Posted : 04/02/2015 2:08 pm
Posted : 04/02/2015 2:13 pm
A mate had a BMW where the climate control sensor was next to the cup holder, so on a warm day you put your nice cold drink in the cup holder and the car thinks 'brrr, it's a bit nippy, better put the heating on'. Vice versa in the winter, too. Genius.
Posted : 04/02/2015 2:58 pm
[i]The hiding them presumably improves aerodynamics.[/i]
I think I read somewhere that it's also to do with saftey, hidden windscreen wipers are less injurious for pedestrians that you hit (on purpose or otherwise)
Posted : 04/02/2015 3:04 pm
Ours was the same - yet did not have wiring for any speakers in the rear or boot... 🙄
Posted : 04/02/2015 3:12 pm
 hora
My Subaru- 6
My old Xsara Picasso 4 in the stupidious places.
Posted : 04/02/2015 3:16 pm
Page 2 / 5
