Sticking Rubber Mat...
Sticking Rubber Matting/Sheet to Ply Wood
10 Users
2 Reactions
My van has a ply wood floor in the rear and I've got myself some rubber matting/sheet that I want to cut to size and permanently stick down.
However, I'm unsure on what type of glue to use, so looking for recommendations. TIA
Posted : 04/08/2023 8:05 am
spray on carpet glue. Cheap and effective.
Aye, same sort of stuff i used in the transit.
Do both surfaces, give it a couple of mins to set a bit, then stick together... Works like a charm.
Posted : 04/08/2023 8:24 am
A tin of contact adhesive would be better value than a spray can. Consider the possibility of high temperature inside the van and its effect on the adhesive bond as well
Posted : 04/08/2023 8:26 am
Contact adhesive or one of skeleton gun adhesive gap fillers. Not gripfill, soudal fix all, sticks like, i cant believe its not nails all will work.
Posted : 04/08/2023 8:53 am
Tin of evostik contact adhesive from Screwfix. It coped with several years of horses stomping over rubber matting on a plywood horsebox ramp
Posted : 04/08/2023 9:07 am
Spray contact adhesive, used this for sticking rubber mat to my plywood rocket plate.
https://amzn.eu/d/c6LEON4
Posted : 04/08/2023 9:11 am
We have a load of thick (18mm) gym rubber matting in our workshop, it just sits on top of 18mm Ply. I installed it in summer and cut the sheets to me mm perfect fit. I notice that in winter, gaps appear between the sheets as they seem to shrink a few mm in the cold. Wonder if glue would stop that, or if they'd just break free...
Posted : 04/08/2023 9:47 am
Just stuck an EPDM roof onto my summerhouse, the glue was just a PVA based one.
Posted : 04/08/2023 10:14 am
Thanks all, gone for some spray contact adhesive, fingers crossed!
Posted : 04/08/2023 3:20 pm
Contact adhesive. You will be far better with the spray stuff. In a can presents it's own problems.
Posted : 04/08/2023 4:30 pm
 bruk
I used B&Q's own spray contact adhesive when putting the floor mats on the wall of my mini mat area. 2 years later and after abuse of 2 small boys bouncing off them they are still sticking perfectly.
Wall mats going up
Posted : 04/08/2023 4:52 pm
