Spraypainting a car...
[Closed] Spraypainting a car panel- lacquer, too?
4 Users
Just painted up a new nearside wing for the wife's C-Max, that I'll hopefully fit at the weekend. Painting went well, although its the first time I've done it. I took it slowly, with lots of sanding and wiping down between coats. Just a final go with very fine graded wet and dry, some light cutting compound then a polish, and then I think its ready to go on.
Except for: how do I know if I need to add a coat of lacquer? Is there an easy way to tell?
Posted : 26/09/2011 7:29 pm
 5AM
If it's a metallic you'll definitely need a coat of lacquer.
Posted : 26/09/2011 7:31 pm
is it metallic? if it is, then yes. if it's a solid colour, then no. as a rule of thumb
Ok, cheers. She tells me its metallic, so lacquer it is. Thanks!
Posted : 26/09/2011 7:45 pm
Laquer should go directly over the final colour coat when it has only just tacked off.
Posted : 26/09/2011 7:58 pm
Cheers Schrickvr6.
Posted : 26/09/2011 8:15 pm
