Trying to seal a glass skylight as it's leaking where some sealant has come away.
The frame is made of alloy with glass in the middle.
Anyone recommend any sealant for the job?
Tried some stuff from screwfix thats meant to work on glass even when it's wet but it won't stick to the glass.
CT1
Arbosil 1096. Prepare the surface (clean, dry and grease free) as per the instructions and you cant go wrong. I think Arbo are the only sealant company to give a 12 year guarantee.
CT1 , its awesome .
CT1. Crickey agreement on STW. Let’s spunk it all over Brexit.
A timely thread as I need a good sealant to redo our leaking shower enclosure. Might give this CT1 a go.
Dow DC785 Sanitary Sealant for bathrooms Andy, anti baterial to stop mould, again a STW approved choice.. can't help on the glass sealant front though.
Use a hair dryer or heat gun to really make sure everything is as dry as possible. At this time of year it can be hard work!
Thanks z1ppy.
Cheers all
I'll give the CT1 a shot.
Soudal, of Soudal fix all, also sponsor Lotto Soudal
https://www.lottosoudal.be/en
But not quite the same as CT1
https://fixall.be/en/products/fix-all-flexi-4
