Realistic rebuild c...
[Closed] Realistic rebuild cost for house insurance?
6 Users
It's that time again and I haven't a clue.
As an example, I've used the ABI calculator and it reckons that my stone built Victorian semi would cost between £223,000-£327,000 to rebuild. It's only worth £160,000.
Seems like a lot of money to me but then again, I'd hate to have a fire and be underinsured...
Posted : 04/08/2014 6:58 am
Generally the rebuild cost is significantly les than the market value - some where between a 1/2 and 2/3. Yours is an unusual situation. Does the RICS website offer any more info?
Posted : 04/08/2014 7:12 am
The market value and rebuild cost generally bear no relation to each other. All depends on location and build materials. Eg a house in London will cost significantly more to buy than to build due to the ridiculous price of the land. However if you had to build a stone thatched cottage in say Newcastle the opposite may be true.
Quite a few insurers will insure up to 500k as standard. Could you not go with one of those ?
Posted : 04/08/2014 7:29 am
 br
[i]Generally the rebuild cost is significantly les than the market value - some where between a 1/2 and 2/3. Yours is an unusual situation. Does the RICS website offer any more info?
[/i]
Maybe, if you've a new built detached in a high-price area - ie land is expensive and only your house burns down.
A Victorian-semi could easily impact the neighbours house and will/could require non-standard materials and probably high-levels of labour etc.
Posted : 04/08/2014 7:47 am
The rebuild cost on mine is much, much higher than the house value. It's the minimum they'd quote for.
Ask your insurer for guidance if you're not sure.
Posted : 04/08/2014 7:48 am
I'm sure that the last time I asked my insurance company, they reckoned £80,000.
I thought that generally, when building, it was a third for the land, a third for the build & a third for profit. Although that doesn't take into account, taking down my house and my neighbours and then rebuilding the buggers!
Posted : 04/08/2014 3:06 pm
Filled in the Direct Line quote thingy with my bigger figure and it hardly changed the premium so better safe than sorry..
Posted : 04/08/2014 8:55 pm
The stone unless it was a monumental ****ing fire would be reused in the most part. 100k will build you a lot!
Posted : 04/08/2014 9:08 pm
