Hi guys,
i have an 2011 orange crush at the moment. if i bourght a pivot mach 5.7C frame how much could i transfer? or should i not **** about and just buy a whole one?
orange spec :
Tubeset 6061-T6 Custom Butted OS Aluminium Tube
Rear Shock N/A
Swing Arm QR Axle
Forks Fox 32 Float RL 140mm TS
F Mech Shimano SLX
R Mech Shimano XT Shadow 10 sp
Shifters Shimano SLX R Fire +
Chainset Shimano SLX (3 x 10sp)
Cassette SRAM PG1050-10
Brakes Avid Elixir 5 185/160
Hubs Shimano Deore 525 Disc
Rims Mavic XM119
Spokes DT Swiss Competition
Tyres Continental Mountain King 2.2
Headset Cane Creek ZST25 tapered
Stem Race Face Ride XC
S Post Race Face Ride XC
Saddle SDG Bel Air
H Bars Race Face Ride XC
Pedals Flat
B Bracket Shimano SM51 Hollow Tech 2
Pivot frame :
• dw-link® suspension with position sensitive anti-squat provides stable handling and the increased cornering benefits of a lower bottom bracket with more travel - all with better pedaling efficiency and a plusher feel.
• New Fox RP23 Kashima shock with custom tuned rebound and Propedal settings for increased rider tunability and incredible small bump sensitivity.
• 142mm rear spacing with 12mm through axle and 160mm post mount dropouts for maximum frame stiffness.
• Under top tube cable guide includes routing for dropper seat post.
• Rubberized leather chainstay, inner seat stay, and down tube protectors for a quiet ride and higher impact resistance.
• Direct mount front derailleur design accommodates Shimano and SRAM systems. The direct mount design, eases set up, and provides a more rigid mount for the most efficient front shifting possible.
• 145mm (5.7”) of rear travel with 140mm or 150mm fork compatibility (150mm standard).
• Press Fit 92mm wide bb shell allows for wider pivots and better bearing support for increased frame strength and stiffness, while maintaining better control over chain-line.
WRONF FORUM!
IGNORE!!!!!!!!!!!!!!!!!!!
