Maths question
[Closed] Maths question
c = b x 150 c = 200 + b
solve for c or b
Any takers?
Posted : 03/06/2015 9:19 am
b=1.34228
Posted : 03/06/2015 9:32 am
You are saying b X 150 = 200 + b?
The fact that it doesn't come to a nice number suggests I've misunderstood.
Posted : 03/06/2015 9:36 am
That's two separate equations right?
Posted : 03/06/2015 9:37 am
[i]b=1.34228 [/i]
I kind of got there by repeated tapping of keys on calculator and doing some binary chops but it doesn't seem to round correctly.
Trial and error doesn't really feel like 'maths' either ๐Ÿ™
Posted : 03/06/2015 9:38 am
Question unclear. Do you mean:
(c = b * 150 * c = 200 + b)
OR
(c = 150b), (c = 200 + b) ?
Posted : 03/06/2015 9:39 am
Iterative solutions are a perfectly valid way of solving maths problems. Assuming that they are two separate equations, then it's just a simple set of simultaneous equations that you have to solve for both b & c.
oh and b = 200/149 or 1.342 if you want an approximate decimal answer.
Posted : 03/06/2015 9:44 am
1.34228 resolves it to 3 decimal places, can't be asked to take it further got enough to do on the spreadsheet today as it is..
Posted : 03/06/2015 9:45 am
My second guess
b = 1/150
c = 200 1/150
Posted : 03/06/2015 9:48 am
If it is two equations then:
[code]c = 150b
c = 200 + b[/code]
Is the same as saying:
[code]150b = 200 + b[/code]
Subtract b from both sides:
[code]150b - b = 200[/code]
Which is the same as:
[code]149b = 200[/code]
So
[code][b]b = 200/149[/b] (or 1.3422818791946308724832214765101 as others said)[/code]
Put that value of b back into one of the original equations:
[code]c = 150b
c = 150 * 200/149
[b]c = 30000/149[/b] (or 201.34228187919463087248322147651 in decimal)[/code]
You can confirm by inserting both values into the other original equation:
[code]c = 200 + b[/code]
[code]30000/149 = 200 + 200/149[/code]
[code]30000/149 = 29800/149 + 200/149[/code]
All Good!
Posted : 03/06/2015 9:49 am
If they're two separate equations, no iteration is needed.
c= 150b
c= 200+b
Therefore 150b = 200+b
150b - b = 200
149b = 200
b = 200/149 = 1.34228.......
c = 200+200/149 = 201.34228.....
edit: too late ๐Ÿ™
Posted : 03/06/2015 9:50 am
as gonefishin says, the exact answer is b = 200/149
I gave the decimal for simplicity.
Not sure why people are doing iteration in here! Have you all forgotten your algebra?! what is the world coming to?!! ๐Ÿ™‚
There are times I despair of that too Stoner. A lack of basic Maths doesn't seem to have the same stigma as a lack of good English*
*Assuming English is your first language.
Posted : 03/06/2015 9:58 am
I'd still like clarification of the question, Graham S suggests two possible interpretations of what was asked.
Posted : 03/06/2015 10:03 am
[i]A lack of basic Maths doesn't seem to have the same stigma as a lack of good English*[/i]
I used a calculator (well google's one) - that makes it maths, right?
Posted : 03/06/2015 10:09 am
To be fair I'm pretty sure it is two equations. If it was:
Then you are saying that c = 150bc, so 150b would need to be 1, so b would just be 1/150
Not sure if we'll get a definitive answer from the OP.
You are usually only allowed one or two bog breaks in an exam.
Posted : 03/06/2015 10:12 am
what ^ said. I assumed that it woul dbe obvious to the OP that if c was a multiple on both sides of the equation then they would have simplified it themselves.
therefore it made sense to assume that it was s simultaneous eq for solving.
Posted : 03/06/2015 10:14 am
It's 2 separate equations.
This time with a wee change
c = b x 150
c = 200 - b
Posted : 03/06/2015 10:23 am
same method then, b = 200/151
Posted : 03/06/2015 10:25 am
c = b x 150
c = 200 - b
Same procedure as above really.
[code]150b = 200 - b
151b = 200
b = 200/151[/code]
http://www.bbc.co.uk/schools/gcsebitesize/maths/algebra/simultaneoushirev1.shtml
Posted : 03/06/2015 10:26 am
