Macro lens question
[Closed] Macro lens question
6 Users
I would like to try taking a few macro shots with my Canon 600d SLR. I have a 50mm 1.4 lens and a 2x converter. Will using those two together be similar to using a 100mm 2.8 macro lens?
I just want to be able to give it a try before deciding wether to splash out on a specialist lens.
Thanks in advance
Posted : 30/03/2012 6:20 am
 WEJ
No, your focusing distance will be no closer than you currently get. Extension tubes are a cheap way to get into close up photography and would still be useful if/when you get a Macro lens.
Posted : 30/03/2012 6:45 am
Your 50mm 1.4 will not fit on your 2x converter. Try googling poor man's macro, see some of the results here.
http://www.flickr.com/photos/slowandeasy/sets/72157594489666715/
Posted : 30/03/2012 7:01 am
Macro lenses focus on things really close. Check the minimum focusing distance of both lenses.
Posted : 30/03/2012 7:20 am
That's news to me. Why not?
Posted : 30/03/2012 8:58 am
Couple of cheap options to try macro without splashing a lot of cash on a proper macro lens:
a reversing ring - basically lets you mount the 50mm backwards to make it into a macro lens
a macro filter - try x2 or x4 filter. Basically like attaching a magnifying glass to the end of the lens.
Posted : 30/03/2012 9:11 am
Cougar,
Sorry, I was thinking of a 2x Extender, I always call my 2x extender a converter. The results from the poor mans macro can be stunning when done correctly.
Posted : 30/03/2012 10:35 am
I'm not wholly sure what the difference is... (-:
Just did a bit of googling. Seems that some lenses aren't compatible because the rear element protrudes too far; also, the Jessop's own brand one states it's not compatible with EF-S lenses. Though, the 50mm 1.4 is an EF lens?
*confused*
Posted : 30/03/2012 10:45 am
Hold on,
You already have the kit. What's stopping you?
Posted : 30/03/2012 10:46 am
True, give it a try.
Posted : 30/03/2012 11:03 am
