Le Torre tap catrid...
[Closed] Le Torre tap catridge replacement
1 Users
 goon
I have a Le Torre bathroon sink tap with up and down for on and off / left right for hot / cold.
There's slow drip from the fitting, underneath the back of the sink. It's not draining in from the stem hole above. I assume it is the cartridge that needs replacing? (It's not dripping from the tap as most of the web links I can find describe.)
There are two types of cartridge, is it possible to determine which to order without dismantling the tap?
Thanks for any help.
The tap:
Posted : 10/12/2014 11:12 am
