We have a Belling fan oven which is doing nothing but blowing out cold air. I have cunningly deduced that the element is probably broken. Is this a simple thing to order up and fit myself? Or will it leave me wishing I had called in a professional?
are you sure you haven't bought a fridge by accident?
Mmmm. Maybe it's one of those cooker fridges?
i did it with mine - the elephant burned out after 10 years.
If i could, you could.
POP. Just don't buy the absolute cheapest off eBay. I did and it went again a few weeks later.
An elephant in your oven, how big was it! Must have been huge to burn for ten years....
Piece.of.piss
I managed it so must be easy!
Got mine online from espares who were great and they even have a video which shows you how to change it.
๐
i had a smeg, ,lovely to look at but utter useless italian reliability, it would blow an element at least every 10 months. soon learned how to go about it.
just make sure you turn off the electricity!!!
Done it a few times on mine since we started cooking homemade pizza on full load. Takes about 10 minutes. If yours is similar, and you can use a screwdriver, you can do it no problems.
Just make sure you switch off at fuseboard first.
Its a piece of piss. Just take it out, check for continuity, if it fails its gone. Go online buy a new one and fit.
i've just done mine!
it was a bit fiddly to remove the terminals, but i got there in the end.
no elephants though...
its very easy, just a bit fiddly
Done mine twice in the last 13 years its been there. It's much easier than the hinges look like they will be to replace (door not closing properly now).
Wot they all said, should be really easy. Check you can easily remove the existing one 1st then order up a replacement. I can utterly recommend the element man [url= http://www.elementman.co.uk/ ]linky[/url]. Not only a great name which IMO is right up there with extractorfanworld and the ironing maiden as best names for a business ever, also has helpful humans behind the website able to patiently answer the most basic DIY questions.
On mine the element was at the back.
It was as simple as turning off the power (don't forget that bit...). Remove the 4 screws holding on the backing plate inside the oven. Remove 3 screw holding in the element. Disconnect the element. Put the new element in and screw it all back together.
Turn on the electricity and ask your wife/life partner to test it with the back of their hand ๐
Then, providing it's working again, test that it gets to the right temp afterwards by either using the sugar melting method or a thermometer (I used sugar).
Hi, replaced the fan motor on girlfriends oven last week.
Built in oven, took less than one hour.
Searched all over the web for a motor then remembered the local appliance spares shop about 400 yards away, got the right one for the job not a universal and cheaper than everywhere else.
Element shouldn't be a lot more hassle.
Hope this helps.
Cheers Kit ๐
+1 for Espares. Easy to find the right part and there's a full tutorial on their site. I found the job simple to do, even with no prior knowledge.
piece of urine.. top blokey job that earns box of brownie points..
+ another 1 for espares.
Easy job.
This 8)
E spares have vids on how to do this if removing ~6 screws is a bit too taxing.....
Umm - Are you sure that couldnt be accessed through the oven door old chap or is one having a giraffe? ๐
Not really, the screws were corroded so had to be drilled out. Also, it's easier to get to the electrical connection.
