Getting a custom ca...
[Closed] Getting a custom cassette cog CNC'd,how much would it cost?
4 Users
I think i've come up with a plan to be able to have cogs on a campagnolo hub going down to 32 or 34,and that's to have a Marchisio cassette,and take thier 30 toothed cog to a CNCer and have a 32 and a 34 made,as 'solid' cogs to keep it simple,ie just with a freehub hole in the middle and teeth around the outside.
Has anybody had anything similar done,and can remember how much it cost?
thanks
Tim
Posted : 19/03/2009 1:03 pm
nope, and a lot, guessing £120-£150
even through essentialy its a 2D job you'd be looking at a couple of hours work and the use of some expensive machinery. Its only realy usefull as a tool if your going to make hundreds and can divide up the cost of programing the machine.
Posted : 19/03/2009 1:08 pm
Right thanks,it was a nice idea i guess.
Tim
Posted : 19/03/2009 1:16 pm
http://www.highpath.net/cycles/cassettes/01.html will do aluminium sprockets in any size.
Joe
Posted : 19/03/2009 1:41 pm
BETD may be able to help?
Posted : 19/03/2009 2:06 pm
Thanks joemarshall.
An Open Pro rim on a Tiagra hub is starting to look like best value though,and the simplest option.
Will keep High Path in mind though.
Tim
Posted : 19/03/2009 2:12 pm
