Have some mean % "scores" for differing categories that I want to plot on a bar chart (doddle, done). Would also like to shove the 95% CI for each mean onto the plot.
(I have the means and the CI calculated for each category & they're on the spreadsheet just as numbers)
How do I get the CI on the chart ?
(I know excel can do the calc itself but can't see how I put em in on the plot - presumably I use the secondary axis, but otherwise ... ?)
May be totally up the wrong tree here ๐ should I be selecting the "raw" scores, inserting a graph and then doing something clever ?
๐
you have to fool the chart builder.
What I usually do is overlay 2x bar charts. The first one is mean + conf, the second is mean - conf, then you can add a third plot with markers at the mean. Make the second bar chart white then you end up with floating bars 2 confs wide with a marker in the middle at the mean.
what stoner said. You need 3 series on the same chart, overlaid
sorry stoner, just lolled
wtf does that lot mean (def no pun intended) ?
(think I may have to use felt tips after all)
How about high low close chart, since I've calculated the 3 variables already ?
Like this I just did:
Create three columns of your data:
Mean - confidence value, Mean + confidence value, Mean
Make a bar chart out of the first two, set overlap to 100 but change the series order if you need to. Then add the markers as a third chart.
Send me the data and I can do it for you quickly enough ...
Depends which version of Excel you're using. If it's 2007, select the data series on your chrt, go to the chart tools tab & there's a button for error bars. Click "custom" and then select the data range that has your numbers in. On earlier ones,, follow the instructions from page 11 of this:
great this, isn't it ?!
remedial excel
I am on 2007, so will try chickadee's 1st - no offence, just that's what I'd imagined it'd be like and I've no real idea how I'm going to overlay. What I'd really like is a histogram with column height equal to the means, then an overlaid line, preferably looking like a capital "I" around the top of the column
off for a play - once I've fed the chillen
cheers one & all
Ignore Stoner's excel advice at your peril. It's usually spot on.
scaredy - this is using the inbuilt error bar function on the line chart type in 2007
[img]
[/img]
you still need to do two charts, the first is your mean histogram column chart. The second is the line chart using the same mean data, but then add "Y-error bars" (both plus and minus) and then link to your confidence differences in the "custom" box at the bottom of the dialogue box.
Oh yeah, I know stoner's good
but <MJackson> [b]I'm baaaad[/b] </MJackson> (actually, chickadee is)
(never really been comfortable with the term, but) *fist-pump* Yesss !
Once I'd worked out what it was asking for, the custom option delivered gorgeously; all without me having to learn how to superimpose things ๐ณ
Thanks folks
I think it's "fist-bump". Fist pump is something entirely different ๐
(on a similar subject does anyone else have to do a double take when the see an ad for "Robson Green's Extreme Fishing" or is it just me?)
oh ๐ณ - never did seem right that the golfers and their wives were doing it on the green in the Ryder cupI think it's "fist-bump"
never seen Robson's offering but do remember somebody on here posting about a book "fisting for Jesus" or something very similar ๐ฏ
