Electrician help ne...
[Closed] Electrician help needed .... dimmer switch question
3 Users
I have a single landing light run from a 2 way dimmer switch at the bottom of the stairs and a normal single switch upstairs. The light is just a typical rose with a standard 40W light bulb.
The problem is that the light is flashing constantly and doesnt react to dimming, howver does improve if i turn it up full and press the dimmer switch sideways hard!!
Do i need a new switch or do i have a comparability issue here?
Posted : 20/05/2012 8:36 pm
What would the 'comparability' (compatibility?) issue be? You say it is a standard lightbulb but do you mean a low energy or a regular filament lamp? Also has it just stopped working whe it worked before or has something changed?
Posted : 20/05/2012 8:40 pm
Get the connections checked in the switch...replace the dimmer with a normal switch (only a couple of quid)see if problem goes away...replace dimmer if it does, if you want to.
Posted : 20/05/2012 8:53 pm
Oh well. As Mikey65 says, replace the dimmer with a normal switch. Not sure why you would want a dimmer on a landing - especially for a 40W bulb. I've seen funny flashy things before with dimmers and low energy bulbs but not regular bulbs. However I did notice that the last dimmer I put in had a [i]minimum[/i] load of 60W which surprised me so it may be that your bulb is too small
Posted : 20/05/2012 9:31 pm
